Replace Oil Pump Or Not???
Old Nov 21, 2004 | 12:17 PM
D21X's Avatar
Default Replace Oil Pump Or Not???
I have a SOHC ZC block with unknown mileage. It still has the OEM oil pump i believe along with original water pump. I will be using a d16z6 head. I've taken the oil pan off and the bottom end looks very good. Should i replace the oil pump and water pump???
Is their a difference between the SOHC ZC oil bump/water and d16z6 oil pump/water??? And does anyone know where i can get them for cheap??? Thanks!!!
Old Nov 21, 2004 | 12:35 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: Replace Oil Pump Or Not??? (D21X)
if theres at least 120K on it (most likely there is) u should replace the water pump and the timing belt as they are hard to get to and most overlooked. oil pump should be ok.
Old Nov 21, 2004 | 12:50 PM
D21X's Avatar
Default Re: Replace Oil Pump Or Not??? (DieMaster)
will the SOHC ZC oil pump have enough pressure/flow for the vtec head???
boostedb18kid
Nov 10, 2007 02:10 PM
bankhead83
Jun 9, 2005 05:41 PM
jsnm
Apr 20, 2005 08:32 AM
Malgerus
Jan 11, 2003 04:33 AM
