How Hard to install AEM Pulleys ?
Old Dec 28, 2001 | 10:52 AM
01itr518's Avatar
New User
Default How Hard to install AEM Pulleys ?
I'm planning on getting these today. I have a Helms manual, but just wanted to know if there are any weird things or special tools I'll need.
Oh, and after installation of the power steering and alternator pulleys, what should I notice? Any ill effects? Couple of horsepower gains?
Thanks guys!
Old Dec 28, 2001 | 01:47 PM
ITR-01-0977's Avatar
New User
Default Re: How Hard to install AEM Pulleys ? (01itr518)
Power steering is so easy its a joke...the altenator can be a pain though....if you have a impact gun use it to break the nut free from the altenator pulley...when I did my si I unbolted the alternator from the car, turned it down (pulley side towards the ground) and zapped the bolt off with the gun and large extension from underneath the car.
Realistically you will see 4-5 whp using both pullies. The only downside I had was at night you could see my headlights go dimmer when my car was just at idle, otherwise everything was fine. If you have a large stereo you may have charging issues with your alternator/battery.Hope this helps.
Old Dec 29, 2001 | 01:39 PM
t's Avatar
t
In case you just skim through the helms. The power steering is reverse threads.
Old Dec 29, 2001 | 01:48 PM
TypeR0149's Avatar
Default Re: How Hard to install AEM Pulleys ? (t)
I hated the pulleys on my old Type R, i dont the think there are worh the hassle or side effects you get from them
Old Dec 29, 2001 | 02:40 PM
1fastGSR's Avatar
New User
you'll get 1 whp at the most. Removing the PS belt is far better and it only gives 3 whp
Midori Green
11
Dec 24, 2006 08:45 AM
slagcker
Nov 9, 2005 07:06 AM
ziggity
Mar 14, 2003 12:11 PM
smokin rubber
Oct 26, 2001 08:06 PM
