timing belt and water pump change - hondaautomotiveparts.com
Old Nov 21, 2004 | 09:58 AM
242 Accords's Avatar
Default timing belt and water pump change - hondaautomotiveparts.com
I need to change my timing belt and water pump..After doing some research I think I will go with OEM parts from hondaautomotive parts... I plan to get the following parts is there anything that i am missing?
1 - Timing belt and balance shaft belt
2- pulley
3- water pump assembly
4- thermostat assembly ( took thermostat out during the summer)..
Those in Philly area, any shops and price suggestion in the surrounding area...
Old Nov 22, 2004 | 06:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: timing belt and water pump change - hondaautomotiveparts.com (242 Accords)
What do you mean by pulley?
In addition to the timing and balancer shaft belt, water pump and thermostat I would also add both tensioner springs, valve cover gasket, new crank pulley bolt (some recommend replacing it), if your model was apart of the front balancer shaft oil seal recall make sure it was done and might as well adjust the valve lash while you have the valve cover off.
Also, if your doing this yourself make sure you have a shop manual to help you along the way.
Old Nov 22, 2004 | 12:18 PM
maroonaccord2.2's Avatar
That's what you do, been there.....done that.
I'm sorry, did you say that you "removed your thermostat" during the summer? I dunno if that's such a "hot" idea. Get it, a "hot," idea?! Bwwaaahahaha!!!!
Old Nov 22, 2004 | 12:35 PM
EX-JAY's Avatar
Might as well replaced all the belts.( ps. belt, alternator...........)
Old Nov 22, 2004 | 10:52 PM
sinister2c's Avatar
Default Re: timing belt and water pump change - hondaautomotiveparts.com (EX-JAY)
dont forget to pick up the balancer seal retainer thing.
mysuperslowej1
11
Oct 30, 2012 05:28 AM
ninerpilot
Aug 16, 2005 07:44 AM
zracer240
Aug 1, 2005 10:07 AM
98LS4dr
Feb 1, 2005 11:36 AM
JaiDieM
Sep 11, 2003 06:55 PM
