GSR vs ITR front CV axel.. the same or diff??
I need to replace the front outer passanger side cv axel on my GSR, but my local store only have one for an ITR. Would an ITR axel work on a 96 GSR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS »</TD></TR><TR><TD CLASS="quote">yes it would. they are the same.</TD></TR></TABLE>
Yup
I do have a question, however. You said, "front outer passenger CV axle." Do you mean the entire passenger side axle? There is only one, no outer or inner. Unless you are talking about just the boot. Or are you talking about the bearings inside?
The driver's side is the one with the "inner and outer" sections because of the intermediary/half shaft and then the axle connected to that.
Yup
