obd1 p13 ecu wiring
dude thats gonna be a bitch.....its like half the car.....actually not that big....but why do you need one.....doesnt the car have one?
either way....you can use any h22/h23 one easily, and im pretty sure the f22 one will work also, and maybe even some accord ones....but make sure theyre obdI harnesses....dont even enter the realm of obdII(it sucks)
Its a h22a4 into a 98 sedan converted to odb1 and thats one of the last few parts I need
I'm going to the junkyard soon, does anyone know if an obd1 accord f22 ecu wiring harness clips plug into a h22a1 obd1 p13 ecu ... just tryng to save some $$
Modified by sedanman at 11:21 PM 11/21/2004
all i can tell you is this...the obd1 ecu clips are all the same, no matter what, if its honda obd1 it will clip in no prob......you can probably use the car's stock harness....and stock civic engine harness, and do your own modifications to get all the extra stuff on it...that way all you need is an obd2-1 ecu adapter and your good....
If I could go to the junkyard and buy a obd1 prelude/accord ecu harness (cut/uncut) I would not need the obd2-1 adapter to save some $ I'm planning to make my own harness to hide the wires for that clean engine bay look.
the ecu harness is the entire underdash harness on an obd1 accord, that harness starts up by the corner lights and headlights, goes down both sides of the engine bay, thorugh the firewall and through the entire dash....good luck!
Teal95Coupe
Aug 16, 2004 07:53 PM
Glen Tennis
Dec 17, 2003 06:06 AM
