anyone using Defi Link Display ???
Guest
Posts: n/a
what is needed for this to work ? i dont really under stand what its saying
Defi-Link Display is a multipurpose monitor which provides information on speed, oil temperature, water temperature, oil pressure, fuel pressure, and exhaust temperature by connecting to the Defi-Link Control Unit II or the Defi-Link Control Unit. Defi-Link Display can be connected to Defi-Link Meters and Defi-Link Meter BFs by using the DAISY CHAIN wiring system.
im thinking all i need is this....
Defi Link Display
Defi Control Unit
here is a pic of the control unit
what im not really under standing is how that unit can read oil pressure, fuel pressure, and exhaust temperature from stock sensors ? if it can then thats kinda a good deal for 400.00 you can read all that on one display!
can somone please help me ?
Defi Link Display
Defi Control Unit
No you need to the contoller then all the gauges that you want to run deom Defi also. You hook up the sensors that come with the gauges to the controller from the controller to the gauges. Thats what ties it all together. The display is optioanl I think.
There are many guys on here that have this setup, I'm sure they can give you a better idea of how it all works.
I believe "Tony the tiger" has this system in his Camry also.
Guest
Posts: n/a
so the controle unit doesnt have come with the sensors ... so i have to buy all the gauges for the link display to work ?... then thats like 1500.00 in guages or somthing ... what would be the point in buying the link display if you have all the gauges ?
you're corret- its liek 1500 bucks. the display unit is an add-on to put all the readings in one place. thats about it. you still need the gauges and sensors and link stuff for it to work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke »</TD></TR><TR><TD CLASS="quote">
That’s not needed
You guys are misleading this guy!
You buy the link display, control unit, and INDIVUDAL SENSORS!
No need to buy the gauges, just the sensors
Do it! You will love it
http://www.defi-shop.com
correct. all you need is the controller unit and the necessary gauges. the gauges come with the wiring you need and other misc. items. the display is another "add-on" you can buy.
That’s not needed
You guys are misleading this guy!You buy the link display, control unit, and INDIVUDAL SENSORS!
I have it! I only have the display on my dash for guages (boost, EGT, Fuel psi, oil psi, oil temp)!!
You buy the display, the controller and the sensors of your choice! The damn pressure sensors require a 1 kidney sacrifice before purchase. I actually already had the gauges so I bought the display and sold the gauges to friends who wanted to be cheap.
Guest
Posts: n/a
if i priced this up right its saying 1,000.00 for everything ... am i right ?
Defi Link Display 280.50
Defi Replacement / Repair Parts: Oil Press Sensor Set (1/8PT) 148.75
Defi Replacement / Repair Parts: Fuel Press Sensor Set (1/8PT) 148.75
Defi Replacement / Repair Parts: Exhaust Temp Sensor Set (1/8PT) 175.95
Defi Replacement / Repair Parts: Boost Sensor 142.80
Defi-Link Control Unit II 109.65
Total 1006.40
does that look right ?
Total 1006.40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceRocket12s »</TD></TR><TR><TD CLASS="quote">if i priced this up right its saying 1,000.00 for everything ... am i right ?
Total 1006.40
Don't you need wires also?
Total 1006.40
Exactly right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee »</TD></TR><TR><TD CLASS="quote">It comes with the wires!</TD></TR></TABLE>
Exactly right
xplizitEK
Oct 20, 2010 08:58 AM
mini-cRx
Feb 23, 2007 02:12 PM
