question
Old Nov 21, 2004 | 05:43 AM
CRX_Control's Avatar
Default question
chould a bad ecu cause one of my injectors to be open all the time?
Old Nov 21, 2004 | 06:01 AM
mrspeaker's Avatar
Default Re: question (CRX_Control)
Your ecu could be bad..
Did you ever mess with the wiring..if so maybe you shorted one of the injectors wiring to the ecu ..
The injector could also be corroded..
Old Nov 21, 2004 | 06:28 AM
Default Re: question (Mrspeaker)
i did convert from obd0 to obd1 with blown90hatch's harness , and i bought a ecu from a honda tech member.Ill try someones ecu just to check tho/
Old Nov 21, 2004 | 06:33 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">i did convert from obd0 to obd1 with blown90hatch's harness , and i bought a ecu from a honda tech member.Ill try someones ecu just to check tho/</TD></TR></TABLE>
Yeah if you have access to a ecu definatly check to see if that solves the problem so you dont have to go pulling apart the injector wires..
Old Nov 21, 2004 | 08:57 AM
Rywire's Avatar
When you did your mpfi swap (I think you said you did one in another post), did you tape up all the wires that were pulled out of the ecu?? Grounding those out can cause that.
Ryan
Old Nov 21, 2004 | 09:27 AM
Default Re: question (droppedcrxsi)
my car came with mfpi, crx hf 88.
Old Nov 21, 2004 | 01:05 PM
Rywire's Avatar
ok, nevermind, I have just see that happen with ecu pins that were grounded out.
Old Nov 21, 2004 | 01:27 PM
thats cool, does anyone know if people can actually fix the ecu? like at a shop or something in town?
josh_db1
May 11, 2010 08:35 AM
jamesfawcett
Apr 12, 2010 08:44 AM
90crxef
Apr 1, 2008 10:02 AM
kur0ryu
May 5, 2004 06:04 PM
SadisticRacing
Nov 13, 2003 08:53 PM
