comp cams stage4 (race only) look!!!!
what do you think about the specs of this cams...did they work on a ls/vtec all motor????
http://cgi.ebay.com/ebaymotors...15213
They are not that big.
Duration at .050 is similar to a JUN 3/ Skunk Stage 2 cam.
Lift is fairly large though. Similar to a Toda Spec C. I think it is actually 12.4mm's of lift on the VTEC lobe. You could use this cam with 12:0.1 compression and be fine.
I just put those cams in my car. Getting it tuned via E-manage. Got it to idle better and 160whp so far. I finish tuning on Monday 11/22. Hoping for just under 200whp.
Stock b18c bottom, P/P head, I/H/E
I have these cams on a Ls-Vtec set up and they work great. They make good power up to 9500 rpm's. No problems so far I have had them in the car for about a month.
Short_Shifter
Feb 6, 2002 01:30 PM
