help. hesitation with 90 wagon
Old Nov 20, 2004 | 11:47 PM
RedEK's Avatar
Default help. hesitation with 90 wagon
ok im stumped still.....alright the vehicle is a 90 wagon. has a d15 block w/a6 head/z6 manifold. there has been a hesitation when giving gas from a stop. i have changes air filter/spark plugs/fuel filter etc. havent gotten to dist cap or rotor but it still does it. there is a plug on the manifold missing, not sure if its the map sensor or tps. but would that be causing it? this plug sits on top of the tb. just trying to figure it out
Old Nov 21, 2004 | 09:26 AM
dr_latino999's Avatar
Default Re: help. hesitation with 90 wagon (RedEK)
Well if was the TPS you wouldn't really go anywhere at all and the MAP I believe you would also have some issues. Maybe you have a vacuum leak on your manifold.
Old Nov 26, 2004 | 09:18 PM
Akiraboy's Avatar
of you gotta pic it would help plus how did you do your mpfi conversion?
maybe something there...just a guess but cam timing or a vac leak like mentioned earlier
Old Nov 26, 2004 | 09:25 PM
Bandit74's Avatar
Does it hesitate when you accelerate just from stop? What about when you accelerate and switch from gear to gear? If it stutters there too, then I'd highly recommend having your igniter replaced.
Here's a thread I made not too long ago:
https://honda-tech.com/zerothread?id=1061263
DemonicRedneck
Feb 20, 2017 08:20 AM
fyjimo_jr
Feb 4, 2015 10:33 AM
T's EG
May 25, 2009 02:33 PM
em14ever
Jun 27, 2007 04:39 PM
civicracer1993
Sep 13, 2002 09:00 AM
