starting to diagnose problem need help making checklist of shit to try
Old Nov 20, 2004 | 10:58 PM
fkncivic's Avatar
Default starting to diagnose problem need help making checklist of **** to try
ok well i had a problem with my clutch not engaging and i covered that in another thread but anyways i pulled it apart checked pressure plat, shift fork, throw out bearing, clutch disk and peddle adjustment. car is drivable now but clutch engages really low to the ground when before i had this problem it engaged really high so that i could slip it off the line when racing. i am running a cable tranny with the hasport cable to hydro conversion kit (slave is fine too), but anyways i still need to try bleeding it which i dont think would cause this much havoc and just wanted to know if anyone else had any suggestions on what to check while diagnosing it? thanks
Old Nov 21, 2004 | 08:52 AM
fkncivic's Avatar
Default Re: starting to diagnose problem need help making checklist of **** to try (fkncivic)
bump
Old Nov 21, 2004 | 01:02 PM
LudeyKrus's Avatar
Bleeding out the clutch line will fix your problem.
Old Nov 21, 2004 | 10:56 PM
fkncivic's Avatar
Default Re: (LudeyKrus)
I hope so but does anyone have any other things to check if it doesnt?
Old Nov 21, 2004 | 11:12 PM
sohczchf's Avatar
Default Re: (fkncivic)
you need to rebuild the slave cylender it has a bad o ring and not building pressure
Old Nov 21, 2004 | 11:15 PM
fkncivic's Avatar
Default Re: (sohczchf)
the slave is new!! what about the master cylinder could that be bad?
Old Nov 22, 2004 | 07:09 AM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohczchf &raquo;</TD></TR><TR><TD CLASS="quote">you need to rebuild the slave cylender it has a bad o ring and not building pressure </TD></TR></TABLE>
Not true. He just did a clutch job and didn't bleed the brakes. That's the problem.
Old Nov 22, 2004 | 07:52 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
I dunno dude, clutch lines can be a BITCH to get air out of. Really annoying. And if this is on a 92-95 then check your clutch master, on the inside of the car. They have a tendency to leak.
Old Nov 22, 2004 | 09:43 AM
sohczchf's Avatar
Default Re: (JDM_Ej)
how old is the master if it is the og from the car it could be
Old Nov 22, 2004 | 11:48 AM
honda_power69's Avatar
I agree, more than likely if you bleed it (be obsessive compulsive about it) it should be fine. Just take your time and keep bleeding until there is absolutely no air, no bubbles, no foam, no anything but straight fluid.
Old Nov 23, 2004 | 11:03 AM
fkncivic's Avatar
Default Re: (honda_power69)
master cylinder is still original the car is a 98 coupe and wtf does bleeding the breaks have to do with a clutch?
Old Nov 27, 2004 | 11:19 AM
fkncivic's Avatar
bump
Old Nov 29, 2004 | 07:21 AM
fkncivic's Avatar
anybody else??
Old Nov 30, 2004 | 10:59 PM
fkncivic's Avatar
one more bump before i give up watching this thread
Soviet67
Aug 23, 2010 09:03 PM
92jdmhatch
Mar 30, 2007 12:35 AM
usdmEHboy
Dec 31, 2006 08:32 AM
B-JUSTINE
Jun 8, 2006 08:51 AM
OverBoost1
Jan 7, 2004 09:11 AM
