91nsx vtec solenoid fit 90 pr3 head??
Old Nov 20, 2004 | 09:02 PM
eda6's Avatar
Default 91nsx vtec solenoid fit 90 pr3 head??
Sometimes vtec doesn't engage. I'm going to replace the solenoid gasket rather than clean the screen. Oil is full, vss works, engine is warmed up, no cels.. It's an intermittent problem. I know a couple of other possible causes but i'm hoping a new gasket will remedy the problem.
I did a search and found out that the 91 nsx vtec solenoid gasket is a replacement for 1st gen b16 vtec solenoid gasket.
Has anybody tried a 91 nsx vtec solenoid or vtec solenoid gasket on their b16?
Old Nov 20, 2004 | 09:04 PM
HatchBox's Avatar
Skoobie no more...
Default Re: 91nsx vtec solenoid fit 90 pr3 head?? (eda6)
why not a del sol, b17 or 99-00 b16a2 gen?
never heard anyone use a nsx part on there b16
Old Nov 20, 2004 | 09:19 PM
ThatRicerDaniel's Avatar
Default Re: 91nsx vtec solenoid fit 90 pr3 head?? (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">why </TD></TR></TABLE>
Old Nov 20, 2004 | 09:24 PM
eda6's Avatar
After reading these threads it seemed like the nsx gasket is the correct one and the other pr3 gaskets/solenoids won't work.
https://honda-tech.com/zerothread?id=238924
https://honda-tech.com/zerothread?id=996694
Seems like it will work since the gasket matches up. Just wanted to know if anyone's tried it.
Old Nov 20, 2004 | 10:07 PM
mrspeaker's Avatar
del sol dohc vtec works..
"alexdog69" said the NSX part worked for him...PM him and ask about it..
Old Nov 23, 2004 | 12:28 PM
eda6's Avatar
Would a leaking exhaust cam plug cause vtec not to work?
Jason Nucom
Nov 27, 2012 06:23 PM
InTheLBC20
Dec 31, 2010 01:00 PM
Luca
Sep 17, 2009 12:26 PM
gringo7718
Mar 18, 2006 09:52 AM
Reelizmpro
Nov 28, 2004 10:43 PM
