b18a1 b18b1 head??
Old Nov 20, 2004 | 08:43 PM
elrandeeto's Avatar
Default b18a1 b18b1 head??
i have a b18a1 in my 90 crx si and today i was given a b18 b1 head would it help my car performance to switch to that head i know i would get alot more out of a vtec head but this wwas free , and has anone used this setup before thanks. oh and the b18a1 is from a 90 not the newer one with a little more power thanks
Old Nov 20, 2004 | 10:31 PM
jdmsijdm's Avatar
Default Re: b18a1 b18b1 head?? (elrandeeto)
as far as i know the b18b heads have slightly more agressive cams and a little bit better flowing port design. if you are running an obd1 ecu, you might want to switch to a 94-95 ecu.
Old Nov 21, 2004 | 01:46 AM
hybrid_vtec's Avatar
Default Re: b18a1 b18b1 head?? (jdmsijdm)
The B18b head flows a little better, other than that it is the same unless you have the IM, in which the 94+ IM is better! IMO have the B18B head machined and save it for when you want to do a build!
Old Nov 21, 2004 | 07:43 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: b18a1 b18b1 head?? (hybrid_vtec)
The b18b IM flows a good bit better. When i was rebuilding my motor i sat a b1 head next to my a1 head and they looked basically the same. I measured both the intake and exhaust ports and they were the same...but the area around the valves on the b1 looked a little larger...so thats prolly why it flows a little better. If i were you id save the b18b head and slowly build it as you get the money. You prolly wont notice THAT much of a difference switching to b1 head if its stock.
Old Nov 21, 2004 | 10:58 AM
elrandeeto's Avatar
Default Re: b18a1 b18b1 head?? (sCeRaXn)
thanks for the info guys i think im gonna do what u have said save it for now and get work done to it and btw i have obd 0
Old Nov 21, 2004 | 04:06 PM
daver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sCeRaXn &raquo;</TD></TR><TR><TD CLASS="quote">The b18b IM flows a good bit better. When i was rebuilding my motor i sat a b1 head next to my a1 head and they looked basically the same. I measured both the intake and exhaust ports and they were the same...but the area around the valves on the b1 looked a little larger...so thats prolly why it flows a little better. If i were you id save the b18b head and slowly build it as you get the money. You prolly wont notice THAT much of a difference switching to b1 head if its stock.</TD></TR></TABLE>
what year was your a1 engine?
d
Old Nov 21, 2004 | 09:30 PM
elrandeeto's Avatar
Default Re: b18a1 b18b1 head?? (daver)
90
Dawsonty
Sep 30, 2008 05:02 PM
kennybintegra
Aug 27, 2006 09:11 PM
redEFnine
Jul 9, 2003 10:35 PM
CLICC916
Jun 21, 2001 10:48 PM
