96 gsr technical help seized engine
Old Nov 20, 2004 | 06:01 PM
drastikchangez's Avatar
Default 96 gsr technical help seized engine
96 integra gsr 98k miles was making ticking noice and turned off wasnt started for awhile and now it wont start. i already had the battery and starter checked out and all i get is clicking noices from the starter. i removed the spark plugs and tried to start it but all i get is clicking noices and ideas on what could be wrong would be greatly appreicated.
Old Nov 20, 2004 | 06:14 PM
Default Re: 96 gsr technical help seized engine (drastikchangez)
anybody
Old Nov 20, 2004 | 11:58 PM
94cxhybrid-T's Avatar
New User
first thing i would do is a compression and leak down test.
were you at idle when it just shut off, had you been racing, was the car burning any oil?
Old Nov 21, 2004 | 04:25 AM
drdisco69's Avatar
Default Re: 96 gsr technical help seized engine (94cxhybrid-T)
He can't do a compression test, the motor is siezed, a leakdown can't hurt, but it won't show fucked up bearings. We can see how bad the pistons ate up the cylinder walls though!
https://honda-tech.com/zerothread?id=1061193
Old Nov 21, 2004 | 02:24 PM
HulkSmash's Avatar
Default Re: 96 gsr technical help seized engine (drdisco69)
can't do a leakdown either. piston needs to be at tdc.
Old Nov 21, 2004 | 03:48 PM
New User
the question didnt really make sense.
He stated that the engine is seized, and then posted that he is trying to start it and had the starter and battery checked.
I was not thinking about the title of the post before i replied, but from his explaination of the problem it sounded like he believed the engine would start, but if it were seized then why even attempt to start it? I would just tear it down and go from there.
Old Nov 21, 2004 | 04:03 PM
notstock93's Avatar
A knocking noise from the engine? Then it wouldn't turn over and idle, now it just sits there and clicks........hmmmm..
All signs point to that engine being in a world of ****. Tear it down, it wont cost you THAT much to rebuild.
guyver13
May 27, 2015 12:15 PM
::ek-4::
Mar 2, 2011 06:26 AM
nothing_shocking
Other Make Vehicles
Feb 26, 2010 09:25 AM
ek9hatch87
Mar 6, 2008 09:01 PM
drastikchangez
Nov 21, 2004 03:04 PM
