tensioner bolt size?for heli-coil
dont use a helicoil.... have if fill welded and retapped.... the timing tenstioner will just pull out again if you use the helicoil. at least thats what happened on a customers car...
take it to someone who knows how to weld aluminum, theyll fill the hole. take the bolt with you, theyll tap the block out and reinstall the same bolt
twentyhurtz
Mar 3, 2014 05:08 AM
Renegade
15
Sep 22, 2003 06:28 AM
