Anybody using a Black Widow BWN-500P 2 way paging Alarm in their TYPE R ??
Old Nov 20, 2004 | 09:45 AM
xunkn0vvnx's Avatar
Default Anybody using a Black Widow BWN-500P 2 way paging Alarm in their TYPE R ??
I just got a Black Widow BWN-500P 2 way paging Alarm installed by Best Buy. Every three days or so I need to jump start the car because the battery dies. I removed the fuse from the alarm and left the car alone for a week to find out if the alarm was instead the problem. It was indeed. My worries is that the stock ITR battery just does not have the capacity to support this 2 way alarm if let alone for 3 days.
My question is... Does anybody else have this alarm system ?? Are you using the stock ITR battery ?? Do I need to upgrade ?? or are there other reasons/ problems why the car battery dies every 3 days ??
Old Nov 21, 2004 | 09:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: Anybody using a Black Widow BWN-500P 2 way paging Alarm in their TYPE R ?? (xunkn0vvnx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xunkn0vvnx &raquo;</TD></TR><TR><TD CLASS="quote">I just got a Black Widow BWN-500P 2 way paging Alarm installed by Best Buy. Every three days or so I need to jump start the car because the battery dies. I removed the fuse from the alarm and left the car alone for a week to find out if the alarm was instead the problem. It was indeed. My worries is that the stock ITR battery just does not have the capacity to support this 2 way alarm if let alone for 3 days.
My question is... Does anybody else have this alarm system ?? Are you using the stock ITR battery ?? Do I need to upgrade ?? or are there other reasons/ problems why the car battery dies every 3 days ??</TD></TR></TABLE>If the alarm is killing the batt. there is a problem with the alarm or the install, the alarm draws wery little power evan when armed, I would also have the batt. checked, most batt. stores will do a load and grav. check on your carr for free. 94
JBB93Coupe
14
Jun 16, 2009 02:11 PM
JDM-EJ1
Aug 7, 2006 01:41 AM
xunkn0vvnx
Nov 20, 2004 11:29 PM
xunkn0vvnx
Audio / Security / Video
Nov 18, 2004 04:09 PM
schwinn
Jun 13, 2002 06:56 PM
