97EX Reverse Wire Harness HELP!!!
Old Nov 20, 2004 | 09:12 AM
ccivic's Avatar
Default 97EX Reverse Wire Harness HELP!!!
I bought a Reverse Wire Harness for my 97 Civic EX last night, and went to install it today. I turned the car off, took off the current caps that were already in place, and just connect the harness to that. So I turn the power back on, and the stock radio is not getting any power. I try to see if my aftermarket radio is still working. It has power, and shows time, and station.. stuff like that, but the CD part doesn't work, and NO SOUND comes out of the speakers. What the hell am I doing wrong?!?! Thanks.
EDIT:
Modified by ccivic at 10:34 AM 11/20/2004
Old Nov 21, 2004 | 09:33 AM
fcm's Avatar
fcm
Old Fart
Default Re: 97EX Reverse Wire Harness HELP!!! (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">I bought a Reverse Wire Harness for my 97 Civic EX last night, and went to install it today. I turned the car off, took off the current caps that were already in place, and just connect the harness to that. So I turn the power back on, and the stock radio is not getting any power. I try to see if my aftermarket radio is still working. It has power, and shows time, and station.. stuff like that, but the CD part doesn't work, and NO SOUND comes out of the speakers. What the hell am I doing wrong?!?! Thanks.
EDIT: You have probably blown the constant power fuse in the engine bay fuse box, probably a 7.5 amp 94
Modified by ccivic at 10:34 AM 11/20/2004</TD></TR></TABLE>
Old Nov 21, 2004 | 11:44 AM
LSP's Avatar
LSP
from what you have discribed, it sounds like your stock unit is dead, the aftermarket one has a bad amp,unless youre running an aftermarket amp and the remote turn on wire wasnt wired into it. It should be a simple swap in a civic.
mad_ox1
Jul 25, 2015 12:27 PM
dlewis2583
Apr 22, 2013 05:38 AM
MilesG
Audio / Security / Video
18
Dec 28, 2008 05:29 PM
pjr710
Aug 22, 2007 11:52 PM
ccivic
Nov 21, 2004 08:08 AM
