Still leaking???
I replaced my valve cover gasket and spark plug tube seals and I still ended up having oil in my sparkplugs and i see light residue of oil around the valve cover. why is that, i belive i tightend the studs as tight as possible but i was also told you dont want to tighten it to much or you can snap the studs, do i need to just tighten them just a little nudge more or what help me out guys, or should i just go ahead and bring it to the shop, the only reason why i didnt bring it to the shop is because they may try to tell me to replaces my wires and spark plugs but there fairly new and i dont want that, just the seals and thats it. help me out guys!
I didnt use any bond stuff, i didnt know i need to<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun »</TD></TR><TR><TD CLASS="quote">you need to use a gasket sealent, like a high heat stuff liek honda-bond. its usually red/ornage and its real cheap. it makes a great seal with anything.</TD></TR></TABLE>
combustion
15
Apr 11, 2005 02:53 PM
