Building turbo header, what pipe diameter and thickness?
Planning to build a stainless turbo manifold for my turbo neon. The exhaust ports are 1.835" x 0.950" ovals. Should I use 1.5" pipe and "flatten" one end out a bit to match up with the port? Also, would you guys suggest schedule 40 304 stainless from McMaster Carr?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie »</TD></TR><TR><TD CLASS="quote">Should I use 1.5" pipe and "flatten" one end out a bit to match up with the port? </TD></TR></TABLE>
I'd like to see pics of that process if someone has time
me as well!!! it would be damn near impossible to "flatten" schedule 40 stainless. Most people(honda's included) just weld the 1.5" schedule 40 on there and then get a good carbide porting bit and from the backside of the manifold smooth out the transition into the piping.
i'm going to attempt to flaten it... if i do it i'll post some pics.. i dont think it's that hard with some heat?
well becarefull so you dont heat it to much cus it will turn it dark and it can rust, i think if you have a press you could flaten it pritty easy,
Oh man, i can just see this getting dangersous. 12tons of pressure on some pipe and then, woops, it pinches out and shoots a hole through your wall~! be carefull man!
So was I! lol
Just think, as it clamps and compresses more and more it'll want to pinch it out and it'll happen pretty fricken quick!!!
It's no longer a header when you use pipe call a roto rooter they will tel you what size to use
lol kidding kidding
what is the sizne of the engine tpye of racing used for rpm rnage etc that will help determine sizing
lol kidding kidding
thanks for the input.
It's a 2.0L dohc engine. Low compression (8.8:1) and holset HX35 turbo. Ported head/intake manifold and crane turbo grind cams. Mostly street driving / drag racing. Looking for 400+hp setup. Usable rpm range 4-8k.
crxnj
11
Apr 24, 2006 01:58 PM
