help with 92 Si
Old Dec 28, 2001 | 05:12 AM
cornbread's Avatar
Default help with 92 Si
Hey guys I’m looking for little help. I just picked up a 92Si a few weeks ago. I traded my Acura legend for it. All and all the car pulls hard and it’s a nice car. It has a few visible performance mods headers, CAI, and cat back. But there is one problem, when the car idles it bounces from 1000rpm to 2000rpm back and forth. Does any one know what could be causing it to idle that way? The guy I got the car from bought it from this guy in NY and he has no idea if he did any motor work to it. Any info will be greatly appreciated
Old Dec 28, 2001 | 05:44 AM
cornbread's Avatar
Default Re: help with 92 Si (smokeeeLSR)
You guys are no help
Old Dec 28, 2001 | 06:06 AM
Spade's Avatar
I have seen this problem before but unfortunatly I don't remember the solution.
Old Dec 28, 2001 | 06:31 AM
cornbread's Avatar
Default Re: help with 92 Si (Spade)
I think i need a new IAC (idle speed motor) does any one think that could be the problem
Old Dec 28, 2001 | 07:41 AM
Spade's Avatar
Idle air control valve? (IAC) Could be an issue. Among other things.....check all of your vaccum lines and make sure they haven't crimpped, rotted, or fallen off. Check your map sensor connections.......get a Haynes Manual that will tell you how to test each and every thing on your vehicle.
Old Dec 28, 2001 | 07:57 AM
Mista Bone's Avatar
D Tranny Guru
usually Fast Idle Control Valve plunger has come loose.
Old Dec 28, 2001 | 08:06 AM
Spade's Avatar
Default Re: help with 92 Si (Mista Bone)
Would you replace the whole valve or just take it off and smack it around a little?
Old Dec 28, 2001 | 01:10 PM
92sleepR's Avatar
New User
Fast idle control valve is the likely culprit followed by a vacuum leak. Check both.
Mike
Old Dec 28, 2001 | 05:35 PM
B18C-EJ1
Guest
Posts: n/a
With that attitude, I'm suprised anyone helped you.
Old Dec 28, 2001 | 06:30 PM
blackANESE's Avatar
Default Re: help with 92 Si (B18C-EJ1)
If you notice he posted that 30 mins after his original question. Patience.
Old Dec 28, 2001 | 10:38 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: help with 92 Si (captainJDM)
could have waited atleast 12 hours, if not 24 hours.
People are so lazy on the internet. They want it now without doing any research!
sonson6
Feb 22, 2008 12:48 AM
SilvrCiv99
Oct 18, 2006 03:43 PM
mikeunreal
12
Oct 25, 2005 08:14 AM
Steve-o
Dec 13, 2002 11:22 PM
whagkangmakulet
11
Sep 14, 2001 07:23 PM
