Main relay problem
Im having what i think to be a main realy problem(have been for a while)
Sometimes it dont click on. It started getting worse lately now sometimes i can hear it click and hear the fuel pump come on but it will bog and hesitate really bad could it still be the main relay.
Also i pulled the main realy out and took the cover off then plug it up and let it just hang there and i could hear it click a lil. but coudnt hear the fuel pump so i shook it a lil then i could hear the pump come on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 »</TD></TR><TR><TD CLASS="quote">try to weld it(resolder) clean it with fine grit sandpaper after....
I thought the correct way was to remove the solder and then resolder it. What's the sandpaper for?
</TD></TR></TABLE>I thought the correct way was to remove the solder and then resolder it. What's the sandpaper for?
well fuel pump was on my mind to. but like i said i can hear the relay click but dont hear the pump prime then i shanke the relay then ill hear it prime
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Replaced the main relay and everything is fine now</TD></TR></TABLE>
haha, sucker. I have main relay problems all the time. I didn't have to replace jack squat though. I just hit the relay with a screwdriver a few times until the car starts.
yeah, i'm really that ghetto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX »</TD></TR><TR><TD CLASS="quote">
yeah, i'm really that ghetto. </TD></TR></TABLE>
My fathers car is like that..
If hittin it dont work he slams the hood and its all fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">
or better yet, when I have weird electrical problems, i just reset the ecu and cross my fingers that my car won't blow up. It's worked for the last 6 months so far...
Normally, I would care, but I'm getting a dohc zc in a month.
</TD></TR></TABLE>or better yet, when I have weird electrical problems, i just reset the ecu and cross my fingers that my car won't blow up. It's worked for the last 6 months so far...
Ya that makes sense,your getting a new motor,don't worry bout the fact that you will have the same wiring for it.Keep your fingers crossed
</TD></TR></TABLE>Ya that makes sense,your getting a new motor,don't worry bout the fact that you will have the same wiring for it.Keep your fingers crossed
I resoldered mine, and it solved my starting problems. Used a soldering iron and a desoldering tool (the bulb type) to remove, and then resolder. You'll need a pretty high wattage iron, there's a lot of material that acts as a heat sink.
If it works, it's a great $0 fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Red CRXsi »</TD></TR><TR><TD CLASS="quote">
yeah, because the wiring is totally going to explode! lol...
the problems are related to sensors that will be replaced when the new motor is in, but that probably didn't occur to you.
</TD></TR></TABLE>yeah, because the wiring is totally going to explode! lol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Sometimes my realy would actually click on and the fuel pump still woudnt prime. Everything is fine now since i replaced it</TD></TR></TABLE>
yea, and it's even worse in the summer!
if anyone needs a good, uncracked solder main relay, hit me up! i have four
boosted_soul_94
Aug 5, 2006 09:57 AM
