Steep Axle Angle & Hood Rub w/ HASport Mounts
Old Nov 19, 2004 | 09:02 PM
doublethink's Avatar
Default Steep Axle Angle & Hood Rub w/ HASport Mounts
b series in a crx, these axles are at a steep angle, and i had so much trouble getting the passenger side to stay in, and it still looks like its about to fall out at any moment.
then i look at this:
http://www.jdmshit.com/hcp/EFfitment/index.html
"The axles are perfectly straight with the EF-18X kit. Since HCP places the motor further back to the firewall, it makes the axles as straight as possible."
"The height of the motor sitting in the engine bay is in the stock location. There is plenty of clearance to fit a B18C GSR or Type R motor in there without the rubbing the hood."
these are both problems ive had.
i also have a decent amount of in car vibration but that is due to the rear tranny mount hitting the crossmemeber, it wasnt bent down enough, which is installer error not a mount problem.
at last my question:
HCP Mount Owners, how far is your downpipe and oilpan from the road at stock height or lowered? I'd like to know please, thanks!
Old Nov 19, 2004 | 09:46 PM
D-series ninja
Guest
Posts: n/a
Hey I dont have any mounts for sale but I will say I run the hcp mounts and they are great I dont have any axle bind,and Im not sure about hood clearance because I have the hood on my car cowled(raised in the back)hopefully you can find a set of the hcp mounts they are cheap and work great!
Old Nov 20, 2004 | 08:58 AM
Default Re: (ef-love)
thanks for your reply, what engine do you run, and how low does it sit?
anyone else with these mounts?
i dont want to buy a new downpipe eveytime i go to taco bell.
Old Nov 20, 2004 | 10:46 AM
john@etdracing's Avatar
Default Re: Steep Axle Angle & Hood Rub w/ HASport Mounts (doublethink)
I have run hasport in my car I have no problem I think your mounts are not the problem
Old Nov 20, 2004 | 10:56 AM
Default Re: Steep Axle Angle & Hood Rub w/ HASport Mounts (john@etdracing)
yes the car isnt perfect, but that isnt what this post is about. im in no way knocking hasport, they make the best stuff around, just not for this particular car.
so back to the point of this topic, downpipe clearance with HCP mounts, anyone got pics or some useful info to add?
but please dont tell me you have hasport and how great they are, because i know they make top notch stuff.
Old Nov 20, 2004 | 01:06 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote"> HCP Mount Owners, how far is your downpipe and oilpan from the road at stock height or lowered? I'd like to know please, thanks! </TD></TR></TABLE>
I have a B18C with the HCP kit and I am also running a DC Sports GSR 4-1 header (not the JDM ITR 4-1). I have 16" Rotas on 205 45 series tires, so that might have played a role in my following measurements.
With the stock suspension I had 4" of clearance from my header to the pavement. Now It's dropped on Koni/GC's with a 2" fender gap all around and my header is 3" from the pavement. The header sits a little lower then the oilpan, the oilpan has a clearance of about 4" (with the car dropped).
HTH
Old Nov 20, 2004 | 05:50 PM
Default Re: Steep Axle Angle & Hood Rub w/ HASport Mounts (BlueShadow)
thank you! you rock for taking the time to do that.
honda-tech
Old Nov 22, 2004 | 06:54 PM
brian g's Avatar
I'd really like to see pictures of this since the real difference in the engine position between HCP mounts and Hasport, is HCP mounts the engine lower. It seems strange to me that you would have an axle alignment problem with Hasport mounts. Please post picks perhaps there is a problem I can help you with.
brian g
Old Nov 22, 2004 | 07:20 PM
EL Vap133's Avatar
Default Re: Steep Axle Angle & Hood Rub w/ HASport Mounts (brian g)
Yup, I have had PR and now Hasport mounts, I have no axle bindage and my axles are straight now. My hood does not rub either.
Old Dec 4, 2004 | 04:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">I'd really like to see pictures of this since the real difference in the engine position between HCP mounts and Hasport, is HCP mounts the engine lower. It seems strange to me that you would have an axle alignment problem with Hasport mounts. Please post picks perhaps there is a problem I can help you with.
brian g</TD></TR></TABLE>
i knew youd chime in eventually!
the passenger side axle just would not cooperate when i did the swap. went through 3 sir clips and i was SLAMMING this thing in the last few times. It could be a problem with the tranny, and this front end did have a small jolt from the previous owner, so its probably just off.
however the axles when the wheel is not turned at all point towards the front of the vehicle about 10 degrees, and also angled downward, but thats going to happen, an axle is supposed to be able to handle that...but anyway it was helping to pull the axle out when i made a 3 point turn. then it started happening even without making any sharp turns. the eventual fix was an axle from autozone, that was like 2 milimeters or so longer then the one i pulled out, i did my best to straighten them and pressed the tranny sides against a straight edge to see. so it could have been a badly made axle, since i know it wasnt oem, thats for sure. also, are the hasport axles any longer then a 91 teg non ABS?
so it wasnt fun and it messed up third gear in the process because i lost so much tranny fluid when i first finished the swap before i noticed it its just a sad story, but not anyones fault, except me, for picking a shitty swap candidate. it was free, come on, who can refuse free?
Old Dec 4, 2004 | 05:17 PM
rice_classic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">yes the car isnt perfect, but that isnt what this post is about. im in no way knocking hasport, they make the best stuff around, just not for this particular car.</TD></TR></TABLE>
What the hell kind of car do you have?
Are you maybe using the wrong axles?
Old Dec 4, 2004 | 06:58 PM
91tegrals's Avatar
no **** wat car did you swap a b18 in too man
Old Dec 4, 2004 | 08:24 PM
Default Re: Steep Axle Angle & Hood Rub w/ HASport Mounts (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">
Are you maybe using the wrong axles?</TD></TR></TABLE>
this is answered in my above post. the cars not perfectly straight. but it was pulled already, so i was looking at other options to relieve pressure from the axleshaft.
Old Dec 4, 2004 | 08:27 PM
brian g's Avatar
i also, are the hasport axles any longer then a 91 teg non ABS?
They're slightly shorter. Sorry about your problems though.
brian g
Old Dec 4, 2004 | 08:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">this is answered in my above post. the cars not perfectly straight. but it was pulled already, so i was looking at other options to relieve pressure from the axleshaft.</TD></TR></TABLE>
the questions were rhetorical and meant for jest. Thank you.
Old Dec 5, 2004 | 12:27 AM
Burlyirishdude's Avatar
been using Avid B series for like 2 months now...the axels are fairly straight...the hood closes on the B16a perfectly...and in the 3 weeks i've been running the car nadda binding. hasports would've been nice...but Pannauto =moto takai desu
jellybeanracer
11
Dec 22, 2012 02:29 PM
playlife
Feb 4, 2012 08:22 PM
kenttouchthis
Aug 24, 2008 04:09 PM
RenzoDaPlayboi
Jul 11, 2006 03:26 PM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
