rack and pinion problems
Old Dec 28, 2001 | 12:41 AM
Markaccord95's Avatar
Default rack and pinion problems
well, i found out why the wheel is pitching, the tie bar (that steers the car) on the right is bent at the joint that connects the inner and outter, and it looks like the left might be slightly bent. Question is, how can you find out if the rack is still in good shape without having to remove it? This is a $500 piece, so if I dont need it, (tie bars are only $80 a side for the inner and outter) im not buying it
Old Dec 28, 2001 | 07:35 AM
Spade's Avatar
Default Re: rack and pinion problems (Markaccord95)
http://www.sohfast.com
Old Dec 28, 2001 | 06:25 PM
up
Old Dec 28, 2001 | 11:42 PM
Mista Bone's Avatar
D Tranny Guru
I just replaced the rack in my 93 Civic, was $50 from local Honda Junkyard.
I snapped the end off a tie-rod when looking for problems and both boots were ripped. $90 in parts for the 2 tie-rods + dust boots.
Just need to gat a alignment tomorrow and I'm done.
BTW my car had 150,000 miles plus 3 frontal incidents.
Jaydeep
Honda Civic (2001 - 2005)
Aug 29, 2012 09:45 PM
meanshyguy
Jun 5, 2010 09:32 AM
stillsmokey
Apr 25, 2008 02:44 PM
efyou
Jun 20, 2006 04:28 PM
DBoost
May 14, 2006 06:25 PM
