Organic brake pads bad for slotted/drilled rotors?
The reason I asked is because I plan to use slotted rotors with EBC green stuff, which are organic. A friend of mine told me that drilled and slotted rotors say to only use metallic brake pads. Is this true?
Maybe you should upgrade a level to EBC Yellow Stuff. Also, on a side note- EBC does make slotted rotors, so maybe you should use their rotors if you are worried about it.
Redline96LX
159
Jun 19, 2014 07:14 AM
dragonkx
13
Jun 29, 2010 07:37 AM
BrakeExpert
Suspension & Brakes
17
Oct 30, 2008 04:18 PM
