Tranny question..Not shifting when accelerating hard
Old Nov 19, 2004 | 06:07 PM
No's Avatar
No
Default Tranny question..Not shifting when accelerating hard
I was driving my car around today.I recently did a fidanza flywheel and oem style clutch on the car.When i drive the car hard in 1st gear...shifting around 6500-7k it will not go into gear.It also makes a very weird noise almost like a whistling/howling noise.i had too adjust the pedal too alow more freeplay then usual for the car too engage its clutch.When i did not have this freeplay it was not even driveable.Im wondering if you think its a bad master cylinder....air in lines(although a steady stream is coming out)....or needs more adjusting..or something else?Any one ever have this problem?Thanks
Old Jan 16, 2006 | 05:59 PM
nomotor's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (narib2oo1)
im having that same problem rite now and i have a fidanza flywheel too! if i drive slow and normal it can shift fine but if i gun it in 1st, 4 out of 5 times it wont go into secound. maybe its the clutch too ( competion ) i dont know and i am trying to figure it out
Old Jan 16, 2006 | 08:26 PM
therealpoorboy's Avatar
if the clutch shifts fine at low rpms and wont shift at high rpms, it means the pressure plate isnt engaging enough. i.e. you need to recheck the fluid in the clutch line and check the line for a small clog. or in a worst case scenario your pressure plate is to weak for the motor.
Old Jan 16, 2006 | 09:06 PM
nomotor's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (therealpoorboy)
thanks
Old Jan 17, 2006 | 04:51 AM
boostinaintez's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (nomotor)
sounds like the transmisson syncros rebuild time man syncros aid into smooth engagement into different gears at all rpm ranges but serve a huge purpose in higher rev shifting and downshifting
Old Feb 11, 2006 | 05:12 PM
93B18Coupe's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (No)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by No &raquo;</TD></TR><TR><TD CLASS="quote">I was driving my car around today.I recently did a fidanza flywheel and oem style clutch on the car.When i drive the car hard in 1st gear...shifting around 6500-7k it will not go into gear.It also makes a very weird noise almost like a whistling/howling noise.i had too adjust the pedal too alow more freeplay then usual for the car too engage its clutch.When i did not have this freeplay it was not even driveable.Im wondering if you think its a bad master cylinder....air in lines(although a steady stream is coming out)....or needs more adjusting..or something else?Any one ever have this problem?Thanks
I'm still waiting for a reply!! Please send me the cash for the parts I didn't get from you.....this has gone on long enough!!
Thanks
Old Feb 12, 2006 | 05:43 PM
Bense's Avatar
and they say we don't need a transmission forum.
https://honda-tech.com/zerothread?id=1510911
Old Feb 20, 2006 | 08:09 AM
93B18Coupe's Avatar
Ok “NO” (As known as “narib2001”)…..Will it be wrong for me to classify you as a scammer? There is obliviously a reason why you are ignoring my IM’s, both e-mail address, and Honda-tech posts. You even have the nerve to post bumps right after my posts with out answering!! Let me know because I don’t want to start warning people of a scammer if it isn’t true??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93B18Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Come on "No" (AKA narib2001) What are you going to do? Are you going to give me my cash back for those parts or not? Please reply to my im's or e-mails. This is crazy!!
Dale</TD></TR></TABLE>
Is this the reason you changed you name to "no"???
Old Mar 7, 2006 | 12:14 AM
93B18Coupe's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (93B18Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93B18Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Ok “NO” (As known as “narib2001”)…..Will it be wrong for me to classify you as a scammer? There is obliviously a reason why you are ignoring my IM’s, both e-mail address, and Honda-tech posts. You even have the nerve to post bumps right after my posts with out answering!! Let me know because I don’t want to start warning people of a scammer if it isn’t true??
Is this the reason you changed you name to "no"???</TD></TR></TABLE>
This is my story People!!
Ok I paid $350.00US shipped for a set of king rod and main bearings, B series piston rings, arp rod bolts and a GE ls/vtec conversion kit. It was stated in the post on Honda-tech that all parts were “NEW IN PACKAGE” Not a bad deal right!! Turns out when I finally get my parts month ½ later the ls/vtec kit was used and had crucial parts missing. He than tells me it was fitted to the engine and removed again and he will find the parts and ship them out to me. I e-mailed him several times, after finally replying he said they were shipped out long ago and I should have received them, (yea right) then e-mails back a while later and said he ordered the parts. Than the next e-mail he can’t find parts to order?? Than he told me to get a price on the parts missing and he will refund the money. I did that and haven’t herd from him since. So since than I have bought the parts from http://tunertoys.zoovy.com/c=9...eagle/ and had them in less than a week!! So $350.00 shipped + $87.70 Sandwich plate (missing) + $19.90 Dowel pins (missing) + $24.33(Shipping) + $56.32 (customs/duties) = $538.25 US $614.79 Canadian. The tap and plug was missing as well but I just bought one at a local shop. Does it still sound like a good deal to you?
Here was the link where I bought it: https://honda-tech.com/zerothread?id=1167447
If you go down to the bottom of the page it he replied to some guy and said “i will not take 120 for the ls vtec kit....i just payed 235 for it...its brand new”
It’s been a while it was modified by him when he removed the parts I bought….I think he had enough time to get me some cash back for sure!! (”Modified by narib2oo1 at 8:30 AM 3/4/2005”)
Well there’s the story and it seems like I won’t be seeing any cash still!!
Later
Old Mar 7, 2006 | 10:15 AM
Used2beAb16's Avatar
eff scammers they make it hard for good sellers to get decent prices for their stuff.
Old Mar 7, 2006 | 11:08 AM
dinko's Avatar
Default Re: Tranny question..Not shifting when accelerating hard (Used2beAb16)
so can you update us on your tranny probelm after that?
cali-boi_eg6
May 30, 2010 04:14 PM
92accordh22a
Jan 17, 2007 07:45 AM
99simoder
Nov 20, 2005 08:18 PM
bboylito
Aug 10, 2005 12:54 PM
streakz
Nov 16, 2003 06:57 PM
