how good are stock b16 rods?
if someone were to turbo their car and get low comp. pistons has anyone used their stock rods? if so what kind of boost can they hold? 250-300 hp....would that be safe?
That is a stock bottom end B18C5 on 93 octane. Though I wouldn't recommend trying this, it's about elaborate tuning. I'd say get all least some Crower Econo rods as long as you are going to have everything apart. Almost anything is safe if it's tuned properly.
But for realistic purposes I'd just go ahead and do it now rather than to wait and see.
I would say the stock b16 rods are good for 250-300hp, but at the very least should have some ARP rod bolts. Also, a good shotpeen and polish is known to increase strenght by 100%.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">they are pretty good... stock honda internals are pretty strong...</TD></TR></TABLE>except D series
would i still have a realiable daily driver if i kept stock internals both pistons and rods? i know it is possible but i would run 7 psi and if im racin some1 faster than me the MOST i would crank it to 10....i do plan to get a better fuel system before the turbo (pump rail regulator and injectors).....also what size injectors for 10 psi??im just tryin to find out so i can tell my parents to get me for x-mas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix »</TD></TR><TR><TD CLASS="quote">except D series
So unfortunately true
</TD></TR></TABLE>So unfortunately true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onePOINTsix »</TD></TR><TR><TD CLASS="quote">except D series </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
Yeah I know..The rods are like paper thin.
And I think the zc's are the weakest....Correct me if I'm wrong..
My friend has a z6 with ls(b18a) rods and susuki vitara pistons and the motor feels real strong...
</TD></TR></TABLE>Yeah I know..The rods are like paper thin.
And I think the zc's are the weakest....Correct me if I'm wrong..My friend has a z6 with ls(b18a) rods and susuki vitara pistons and the motor feels real strong...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si »</TD></TR><TR><TD CLASS="quote">would i still have a realiable daily driver if i kept stock internals both pistons and rods? i know it is possible but i would run 7 psi and if im racin some1 faster than me the MOST i would crank it to 10....i do plan to get a better fuel system before the turbo (pump rail regulator and injectors).....also what size injectors for 10 psi??im just tryin to find out so i can tell my parents to get me for x-mas</TD></TR></TABLE>
anyone run stock internals with no problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">My friend has a z6 with ls(b18a) rods and susuki vitara pistons </TD></TR></TABLE>
Now THATS a hybrid!
And as far as turning up the boost for faster cars, remember that there will always be someone faster. Find a maximum limit for the engine and obey it, and accept the fact that you have a fast car with stock rods. If you try to push it to something it can't do, it will go from fast to nothing very quickly. As they say, to finish first, first you must finish.
Now THATS a hybrid!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si »</TD></TR><TR><TD CLASS="quote">thanks
but it could handle 7-10 psi safely correct</TD></TR></TABLE>
Depends what turbo you use and who tunes the car..
10psi with a t25 isnt the same as 10psi with a 60-1..
