Main relay buzzing
Old Nov 19, 2004 | 03:33 PM
Acuraman918's Avatar
Default Main relay buzzing
I tried switching a dpfi motor to mpfi unsecessfully. I am turning it back to dpfi, and the first crank it ran poorly on two cylinders then died. I have been messing with the ecu. now the main relay is buzzing and I checked the ecu fuse, and it's fine. my main question is what else would make that relay buzzz?
Old Nov 21, 2004 | 08:04 AM
Default Re: Main relay buzzing (Acuraman918)
bump, is it always a bad ground?
Old Nov 21, 2004 | 08:27 AM
POORmansHATCHBOX-t's Avatar
yea try checking all grounds...when mine was buzzing it was the thermostat ground on top of the thermostat. alls i did was tighten one bolt up and my b16 fired right up. not sure if its the same with your setup but def check for loose/missing grounds. good luck...
Jenkinsal2
Engine Management and Tuning
Mar 14, 2010 11:26 AM
RMXmitch
Nov 1, 2007 03:46 PM
tragiclude875
Mar 26, 2007 06:00 PM
Hondasaurs
Apr 11, 2003 02:25 PM
