Knock senser code???
Old Nov 19, 2004 | 01:39 PM
00000xxx's Avatar
Default Throwing Knock senser code???
why would my ecu (0BD2) be throwing a code for the knock sensor???? and how can i fix it???
Modified by ctr610 at 6:33 PM 11/19/2004
Old Nov 19, 2004 | 03:42 PM
PrettyLude's Avatar
it's either picking up knock, a bad sensor or unplugged sensor
Old Nov 19, 2004 | 05:29 PM
00000xxx's Avatar
Default Re: Throwing Knock senser code??? (ctr610)
how can i tell if its a bad sensor??? i run 93 octane in a b16b so it shouldn't be detotnating
or
can it be my N1 crank pulley?? because its not harmonically dampered and the knock sensor may be picking up those pulses...im gunna throw the pulley cluster on tomorrow to see if thats the case
Old Nov 19, 2004 | 09:32 PM
skunk2finatic's Avatar
your knock sensor doesn't thrown a code because it senses a knock....you won't actually know it even does anything! it adjusts your timing whenever it detects a knock, thats all. If your engine light is coming on then the plug isn't connected properly or your sensor is bad. Either way, thats the only two ways that code will come up. Ask me how I know?? I run ODB tests everyday, diagnose ecm problems all day every day.
Old Nov 20, 2004 | 07:15 AM
00000xxx's Avatar
Default Re: Throwing Knock senser code??? (skunk2finatic)
amazing.... im gunna get the engine wire harness schematics and make sure i have the right sensor clip on there then go from there
Old Nov 20, 2004 | 11:12 AM
PrettyLude's Avatar
you sure it doesn't throw a code, if that's the case, how come they have a code for knock sensor?
brcivic411
17
Aug 26, 2011 01:15 PM
SpoonFedEj8
Dec 23, 2008 03:11 PM
hatch34
Mar 16, 2005 12:49 PM
Trygge
May 14, 2004 09:16 PM
Fardoche
Jul 31, 2003 10:29 PM
