TEMP Gauge Issue!!!!!
I have a problem on hatch.. hopefully someone can cure this. My temp gauge goes up once in a while and i notice that my fan doesn't turn on when this occur. I tested the fan and it's working fine. I believe it's the temp switch behind the block. I bought one today and I'm going to put them on this weekend. The main issue is I notice when my temp goes up driving at night and my headlights are on.. If I turn the headlights off the temp gauge goes down!
could this be the temp switch or could it be something else?
Sounds like an Electrical problem. Maybe a bad ground. I had a friend whos temp gauge went up with he turned on his light.... = bad ground strap at battery
Littleman456
Nov 14, 2013 05:33 PM
madman4you
May 15, 2007 09:44 PM
