reasons for no heat???????????
Old Dec 27, 2001 | 09:11 PM
IWearMyKswiss's Avatar
New User
Default reasons for no heat???????????
what could be some reasons why my car has no heat,..i need info fast
Old Dec 27, 2001 | 09:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: reasons for no heat??????????? (WiDeBoDyEK)
Like as in no heat from the heater?
Are you sure the cable from the cold/heat is working properly? It could be broken or something along those lines
Old Dec 27, 2001 | 10:49 PM
Yesman's Avatar
New User
Default Re: reasons for no heat??????????? (B18C-EJ1)
heater coils..?
Old Dec 27, 2001 | 11:05 PM
New User
Default Re: reasons for no heat??????????? (bishop)
any idea on how to fix these to options???
Old Dec 28, 2001 | 01:39 AM
BlackB18C's Avatar
One reason would be a bad heater core. If that's the case you might end up pulling your dash. Check all your harnesses near the firewall. A friend of mine thought his h/c went out and it ended up being a loose connection somewhere near the firewall
[Modified by BlackB18C, 10:42 AM 12/28/2001]
Old Dec 28, 2001 | 05:43 PM
New User
Default Re: reasons for no heat??????????? (BlackB18C)
i dont have to pull the WHOLE dash do i???,..as in like the upper part,...the lower pieces can be taken out with ease,...thanks for the info
Old Dec 28, 2001 | 05:50 PM
RICEBURNER1406's Avatar
New User
could be the blower motor.
typeRaccord
Mar 5, 2006 12:27 PM
Josue
Oct 21, 2005 07:43 AM
sleepin91teg
19
Mar 14, 2005 08:37 PM
lonefuzzy79
Oct 8, 2003 12:37 PM
boostinb18
Dec 26, 2002 02:00 PM
