WHAT FLYWHEEL TO GET????
Old Dec 27, 2001 | 08:58 PM
JU-JU's Avatar
Default WHAT FLYWHEEL TO GET????
I'M LOOKING FOR A FLYWHEEL FOR MY EK. I HAVE A JSPEC GSR 96' AND I NEED A FLYWHEEL. WHAT ARE MY OPTIONS. IT WILL BE A N/A AND A DAILY DRIVER CAR SO PLS. GIVE ME SOME INFO...
Old Dec 27, 2001 | 09:13 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: WHAT FLYWHEEL TO GET???? (JU-JU)
first option is to find the caps lock key.
Old Dec 27, 2001 | 09:31 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: WHAT FLYWHEEL TO GET???? (Mista Bone)
Yes, please fix your caplocks problem.
You have many options. Personally I like the clutchmasters 7.5 flywheel.
But that's just my opinion.
BTW - they're $280 on http://www.groupbuycenter.com
Old Dec 27, 2001 | 11:26 PM
Turbo EG6's Avatar
New User
Default Re: WHAT FLYWHEEL TO GET???? (B18C-EJ1)
https://honda-tech.com/zerothread?id=92285
Old Dec 28, 2001 | 12:47 AM
KJEG94's Avatar
New User
Default Re: WHAT FLYWHEEL TO GET???? (Turbo EG6)
im going through the same dillema....
ive narrowed it down too
Fidenza 8lb
clutchmasters 7.5 lb
toda!
Old Dec 28, 2001 | 08:42 AM
B19CivicHB's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (DragonCTR69)
I agree with dragon but i opt for the JUN 9lb flywheel. I have it and it weighs in at exactly 4.2 kg. Its noticably lighter than my stock GSR flywheel but not so light that it destroys all driveablity. I say go with JUN.
Old Dec 28, 2001 | 09:40 AM
TODAwhore's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (B18CivicHB)
Jun starter problems, unless you find the right starter that works with it..go either Toda or Spoon no problems and great for every day car. they weight 9.1T or 9.3Slbs
Old Dec 28, 2001 | 10:05 AM
spoonek4's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (SpoonDeg)
Agreed
Old Dec 28, 2001 | 12:28 PM
Thrashin's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (KJEG94)
Fidenza 8lb
toda!
fidenza
Old Dec 28, 2001 | 12:44 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: WHAT FLYWHEEL TO GET???? (jdmeg6)
Fidanza = Clutchmasters = Fidanza
No difference.
Old Dec 28, 2001 | 01:04 PM
iviikoivi's Avatar
TODA
Old Dec 28, 2001 | 01:08 PM
jeff652's Avatar
Dragon, you ever drive a 7.5 lb flyweel equipped Honda?
I have clutchmasters in my track racer EG, and my commute car Type R. My wife didn't even have problems switching over fromt he stock fly when I installed it. She has 0 problems with it's "drivability" and actually loves the improved throttle response . . an 8lb flywheel is 110% streetable. period.
Get a clutchmasters, you won't regret it . . .
From someone who knows *first hand*
Jeff
Old Dec 28, 2001 | 02:23 PM
swarsing's Avatar
clutchmasters=100% streetable daily driven 93sihb w/b18c1 daily driven,no low end loss
Old Dec 28, 2001 | 05:42 PM
deepnite's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (swarsing)
im about to find out how the clutchmaster fly wheel works with my ACT clutch...
Old Dec 28, 2001 | 06:05 PM
Kamin's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (deepnite)
ive got a clutch net in my new engine, ill let you know in 1 WEEK!
Old Dec 28, 2001 | 06:10 PM
B18C-EJ1
Guest
Posts: n/a
I can tell you exactly how it is.
You'll love it.
Old Dec 28, 2001 | 10:14 PM
milo's Avatar
SPOON!!!
Old Dec 28, 2001 | 10:26 PM
SPOON_BeIgHtEeNsEe's Avatar
JUN
Old Dec 29, 2001 | 03:29 AM
From: LA, Hawthorne, Alhambra, Monteghetto, CA, USA
im using a jun one and i have no problems with it......
Old Dec 29, 2001 | 04:43 AM
owen_the_soyboy's Avatar
No I have never driven a 7.5lb Flywheel but it's simple Physicis...
Thats just funny that you try to use physics to disprove what people actually DO feel as far as results with a new lightweight flywheel in the real world. How can you tell someone that what their results were must not be possible, that just does not make sense... I think you should keep your comments to a minimum if they are 'speculation' (trying to be nice, not harsh). Even though they are based on sound principles of physics, there are some things that are not always as simpleas they seem, and what does look to be true is that a 7.5lb flywheel on a honda or hybrid honda is a mod that does NOT hurt drivability for street use.
Old Dec 29, 2001 | 07:54 AM
kefka's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (iviikoivi)
if its a "daily driver" then why do you need a lightweight fly wheel...
Old Dec 31, 2001 | 09:43 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Personally I'd go with a Type R Flywheel... It's lighter than the Stock GSR (12lbs) but not too light... if you go with a JUN (9lbs) you're still going to loose more low end torque... ...
i don't get it. are you saying that a gsr flywheel is 12lbs? stock itr flywheel is 15.4 lbs, so my guess is a gsr flywheel is 18, perhaps 20 lbs.
Old Dec 31, 2001 | 10:39 PM
f0de's Avatar
Default Re: WHAT FLYWHEEL TO GET???? (rodney)
i like my UR flywheel, which weighs in at 8lbs.. didn't notice any low end loss.. just more responsive.. it was a bit on the expensive side tho
HondaH22A
Apr 24, 2003 05:34 AM
SpoolnG2
Jan 20, 2003 04:24 PM
fire7882
Apr 25, 2002 02:16 AM
DA666
Dec 27, 2001 07:37 AM
