b18b1 or b16a2
Old Nov 19, 2004 | 05:20 AM
crackerjacker006's Avatar
Default b18b1 or b16a2
i have a 99 ex coupe and i want to swap the sohc but i wanna know if i would be better off going for the b16a2 or saving a little money and getting the non vtec integra motor. I will eventually start to build the motor i get but right now im havin trouble with getting money for a motor. so should i save money and get ls motor or save up money and get the b16a2? Open to any suggestions.
Old Nov 19, 2004 | 05:25 AM
mwieczorek43's Avatar
Default Re: b18b1 or b16a2 (carjacker006)
I would say get the b18b1.
There is no replacement for displacement.... (except for a bigass turbo).
You could build an LS-vtec and it'd be great all motor.
Or you could throw 10lbs of boost at it, and it'd be a great turbo car.
I personally feel that the b16's are overrated. But my opinion is slightly slanted due to the fact that I have an LS in my hatch.
ps. you might get flamed for starting this thread. not alot of tech involved.
Old Nov 19, 2004 | 05:34 AM
dohcdelsol93's Avatar
Default Re: b18b1 or b16a2 (mwieczorek43)
n/a B18B1 owns a n/a b16a2
Old Nov 19, 2004 | 05:46 AM
Phantastic's Avatar
i say go with b18b b/c i agree with mwieczorek43 and b/c b16 are overrated
Old Nov 19, 2004 | 05:54 AM
Default Re: b18b1 or b16a2 (Phantastic)
i figured most people would say b16a2 but i guess the b18 has more potential in the long run.
Old Nov 19, 2004 | 06:02 AM
handa's Avatar
I had trouble deciding on the two a while back, and I went with the B16a. I wish I went with a B18, perhaps B18C GSR, because my B16a feels just like my D16z6. Although B16a VTEC is addicting.
In the end, it comes to what you want to do with your motor: Turbo or N/A, or both. It's personal preferences.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">n/a B18B1 owns a n/a b16a2</TD></TR></TABLE>
And I've heard on H-T before that on same chassis and driver, B16a will destroy B18B everytime. But don't let the E-racing decide what you want.
Old Nov 19, 2004 | 06:35 AM
colinproctor's Avatar
Default Re: b18b1 or b16a2 (handa)
just save for longer and step up to the b18c-r
Old Nov 19, 2004 | 06:44 AM
JDM EJ1 95's Avatar
theyre almost exactly the same from the start... i have a ls engine in my coupe and i turned a 15.200 at 91.2.. my friend has a JDM B16a in his 98 hatch and he turned a 15.17.. both cars have I/E... but the ls has more potiential and more choices in the long run.. the b16 is also a good turbo engine but it usually will not perform as good as a 1.8 all motor
Old Nov 19, 2004 | 06:50 AM
eg92b16a2's Avatar
Default Re: (JDM EJ1 95)
B18b are cheaper to get than B16a.. go with B16a for now and then when you are bored with it pick up a LS block for cheap and go with LSVTEC.
Old Nov 19, 2004 | 07:16 AM
Default Re: (eg92b16a2)
the b16 is tools, get a b18b1 and throw a b16 or gsr tranny with it. If your staying n/a for a while the only thing your going to get from a b16 is alot of noise at 7 grand. You can't lose with a longer rod.
Old Nov 19, 2004 | 08:00 AM
CivicSiR's Avatar
Default Re: (dohcdelsol93)
get the b18b1, i have one in my hatch along with a gizzer tranny and love it. i have plans on boosting it too.
look at it this way, when your boost the **** outta your LS and blow it up, you not going to have to shell out nearly as much money as if you blow up your b16
Old Nov 19, 2004 | 03:12 PM
noahblkmale's Avatar
Default Re: (CivicSiR)
Go with the b18b1 u gonna waste your money on a b16 if u do...or just save like i did and get the gsr u will love that
Old Nov 19, 2004 | 03:14 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (noahblkmale)
if you plan on boosting i'd say go with the b18b.
Type 56
Engine Machining & Assembly
Mar 31, 2016 11:46 AM
K20b-Curb
Dec 30, 2014 06:21 AM
ekhatchswap
Jan 7, 2007 06:36 PM
curiousgpnoy
89
Dec 19, 2002 06:41 PM
