Thinking about buying '99 EX sedan in 5-speed for my girl?
Just put a deposit on a '99 Civic Sedan EX. 62k on the clock, 5-speed, VTEC 1.6, power tilt and slide roof, ABS, fenders and rear bumper VIN's match. carfax is good. Got teh guy down to $9,000 even. Sound like a good deal I am taking it to a local Honda only shop to have them put it on the lift. Any weak points I should look for in this series?
Sounds a little expensive, definitely being 4 door but the mileage looks really good. If its not to late and you wanna sacrifice some space for looks, find a civic coupe.
I picked up my 2000 EX coupe for $8600 with a back bumper that was peeling clear coat and 71,xxx miles. It's up to you
it sounds like an ok deal if the car is in extremely good shape (i.e. exterior is perfect and you can eat off of the interior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carjacker006 »</TD></TR><TR><TD CLASS="quote">Sounds a little expensive, definitely being 4 door but the mileage looks really good. If its not to late and you wanna sacrifice some space for looks, find a civic coupe.</TD></TR></TABLE>
whats wrong with a Sedan?
If it's in great shape I don't think it's that bad a deal at all. Mileage is good, I got over 90K on my 98 already. Sedan is alright as long as it's 5-speed! Sport sedans & wagons are all the rage these days it seems...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr »</TD></TR><TR><TD CLASS="quote">
whats wrong with a Sedan?</TD></TR></TABLE>
heavier than a coupe, thats what I think the guy ment. (you drive a sedan dont you? lol) Either way..if you want it for daily driving, then its a good car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">heavier than a coupe, thats what I think the guy ment. (you drive a sedan dont you? lol) Either way..if you want it for daily driving, then its a good car.</TD></TR></TABLE>
i cant believe you said that. time to correct you like all the others.
<FONT COLOR="blue">Vehicle Curb Weights for almost EVERY Honda/Acura before 2003</FONT>
please visit that link and let me know what the 99 EX Coupe MT wieghs in comparison to the 99 EX Sedan MT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr »</TD></TR><TR><TD CLASS="quote">i cant believe you said that. time to correct you like all the others.
please visit that link and let me know what the 99 EX Coupe MT wieghs in comparison to the 99 EX Sedan MT. </TD></TR></TABLE>
Reading comprehension owns you. I said, I think the guy ment to say that the sedan is heavier than the coupe. Did I say the sedan was heavier? I was only merely stating what I think the other guy said. NIce try on a weakass Flame
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">Reading comprehension owns you. I said, I think the guy ment to say that the sedan is heavier than the coupe. Did I say the sedan was heavier? I was only merely stating what I think the other guy said. NIce try on a weakass Flame
your right, your right.....
</TD></TR></TABLE>your right, your right.....
My girl and I just purchased the ’99 Civic EX sedan, 5-speed, ABS, clean carfax, with 62k on the clockwe talked him down some more to $8,300 at a stealership. It is a little louder than most stock Civics in the engine bay. A Honda specialist says it is either the bearings on A/C’s tensioner pulley or the nut on the shaft of the pulley is to tight. I took the power steering pump, and belt off and used a serpentine belt tool and it BROKE while trying to loosen the nut on the A/C tensioner pulley! I soaked the bearings of the tensioner with WD-40 but it was only quite for like 5 min. Is this a common problem with the 1.6 VTEC/6th gen Civic with A/C?? Thanks for your help. It is REAL CLEAN except for a light rear drivers fender bender that was fixed OK by a body shop. Also has a KILLER stero in it. When I change the coolant and the manual tranny fluid what should I use? I am going to change the power steering fluid also. Plugs would be a good idea what kind, wires look good.
I took the power steering belt off and it sure looked like a flat ribbed belt to me??? I know it has seperate belts for each assc. but they are flat ribbed belts?
Another Honda dealer just printed out service bulletin # 00-003 from Honda stating that "Growl from A/C Idler Pulley" is common from idler pulley bearings be faulty!! I guess others have had this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9hatch0WN3R »</TD></TR><TR><TD CLASS="quote">woa buddy! 9k is quite a bit IMO for that kind of milage on a 99</TD></TR></TABLE>
did you even read this? he ended up paying 8300.
still sounds a tad high. remember this is a civic. mileage of 100k is NOT high. id say if ya can get it to 9k with T, T, and T, then that sounds pretty reasonable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortlid »</TD></TR><TR><TD CLASS="quote">Are the side moldings under the doors on a '99 EX sedan in Green Clover supose to be flat black or body color??</TD></TR></TABLE>
all EK Sedan side skirts i have ever seen are flat black.
If you gave a deposit pending inspection it sounds like you're comitted. I think most would say the price depends alot on what region your in. When I shopped early this summer in the Seattle area the prices I found for 'Excellent' shape LOW milage Civics was 1999 = $9000 98 = $8000 97=$7000 @ mid 90's the prices drop off. Honda's hold their value but there are always alot of them for sale so it's really a buyers maket. If it's a creampuff and checks out okay mechanically, needs no work (brakes etc.) then no buyers remorse for you @ 9k with sevice records / one owner etc.
KBB.com private party value for that car in "excellent" condition is $9,420
private party value in "good" condition is $8,780
Suggested Dealer retail for that car is $11,160!!!
Thanks Nonsense, that is what we saw in NADA and KBB.com when we were looking at it. I mean they were asking $10,995 which I though was crazy we went back THREE times before we even put the deposit down. Then we talked it down some more to $8,300 after a local Honda specialist shop checked it out for us.
go buy it new if your that picky about the car dame i hate fools like you, you look everywere and ask 101 questions and at the end you dont buy . for your girl what a puss
