vacuum leak through FMU?
Old Nov 19, 2004 | 03:33 AM
scartail's Avatar
Default vacuum leak through FMU?
I was going thru with my soapy water and saw some leaking around the screw location. Pretty much all of them was leaking. Anyhow, I tighten them some and it seem the leak stopped. Is this a sign of some bad? Could that small leak cause something esle?
Any advice will be great.
Thanks.
Old Nov 19, 2004 | 04:39 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: vacuum leak through FMU? (scartail)
As long as they’re all tight now you should be fine! If it’s leaking in boost and the FMU is not seeing all the boost you very well could be starving the motor for fuel!
BUT if you tightened all the fittings up and there seems to be no leak now then you are fine
Old Nov 19, 2004 | 11:48 AM
scartail's Avatar
Default Re: vacuum leak through FMU? (si2die4)
cool thanks... i'm going to throw in a fuel pressure gauge one of these days. :-D
Old Nov 19, 2004 | 03:19 PM
pornstarSR's Avatar
i had a warm up idle fluctuation that was strange cause i know i didnt have any air bubbles in the coolant, and no hugh vacuum leaks....
but 2 days ago i swapped out fmu's to check something else completly.
and my warm up idle is fine now.... so they can leak, and they suck.... i hate mine
check sig, i need to get rid of it, standalone(i want aem) is the only way to go
Old Nov 19, 2004 | 04:15 PM
scartail's Avatar
Default Re: vacuum leak through FMU? (pornstarSR)
yeah.. i know the FMU isn't the best... but since im still battling other problems... like no boost... i'll have to hold off on anything thing else right now...
Old Nov 20, 2004 | 11:24 PM
pornstarSR's Avatar
yeah no i understand that, wasnt trying to sell you anything.... i read my post again and it seemed like that.....
how you get them sorted, as i have learned, EVERYTHING can be to blame
Silent_Destruct
May 24, 2006 02:10 PM
paul93sir
Feb 10, 2004 05:30 AM
asianspeed
Mar 13, 2003 04:51 PM
hybridb18
Dec 11, 2002 04:30 AM
