BLOX Sway Bars - In stock! $139.99
BLOX Sway Bars
The BLOX 21mm rear sway bar kit is an excellent addition to any suspension upgrade. The BLOX sway bar comes in a powder coated red finish and comes with all the hardware.
$139.99
CLICK HERE TO ORDER
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conFusedEG »</TD></TR><TR><TD CLASS="quote">Pics on a car please preferably a hatch.</TD></TR></TABLE>
Sorry, don't have any
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">No CRX?</TD></TR></TABLE>
Sorry, no CRX right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nyceguy17 »</TD></TR><TR><TD CLASS="quote">IS a rear tie bar compatible with this at all?</TD></TR></TABLE>
BLOX says it should work just fine with rear lower tie bars.
Thanks guys!
Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowaywhatthehell »</TD></TR><TR><TD CLASS="quote">are the end links included?</TD></TR></TABLE>
I can find out from BLOX on Monday... Have a great Thanksgiving!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostreetonline »</TD></TR><TR><TD CLASS="quote">
I can find out from BLOX on Monday... Have a great Thanksgiving!</TD></TR></TABLE>
did u find out about the end links?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar »</TD></TR><TR><TD CLASS="quote">do you need aftermarket lcas when you put this on an eg?</TD></TR></TABLE>
Of couse you'll need to use either the lca from a compatable vehicle that came stock with a rear sway bar or buy a set of aftermarket lca w/swaybar mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC »</TD></TR><TR><TD CLASS="quote">
Of couse you'll need to use either the lca from a compatable vehicle that came stock with a rear sway bar or buy a set of aftermarket lca w/swaybar mounts.</TD></TR></TABLE>
thanks i was 99% sure I just wanted to be 100%.
nice av bleeding through
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superstud »</TD></TR><TR><TD CLASS="quote">back from the dead... are these still available?</TD></TR></TABLE>
Available... in stock!
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy »</TD></TR><TR><TD CLASS="quote">any info on the end links?</TD></TR></TABLE>
Sorry guys, no end links.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esoterEK.. »</TD></TR><TR><TD CLASS="quote">im interseted but will this clear with a * benen lower tie bar on an EG hatch*</TD></TR></TABLE>
I'm unsure. If anyone knows, please chime in! Thanks!
deary09
Nov 11, 2011 05:25 PM
