1998 Civic.... Is this correct operation of the locks?
Old Nov 18, 2004 | 08:36 PM
Intercooler's Avatar
Default 1998 Civic.... Is this correct operation of the locks?
I can't lock all four doors with the switch. The driver's side door stay up Now if I take the key and do it from the outside with the door closed it will go down. As far as that goes just turning the driver's side from the outside will put all of them down regardless. Is this a safety feature so you don't lock your keys in the car? Just trying to find out before I rip into the door.
Old Nov 18, 2004 | 08:38 PM
inline4's Avatar
Default Re: 1998 Civic.... Is this correct operation of the locks? (Intercooler)
you have to hold the driver door handle(inside) open to lock the drivers door when u lock the rest of em.
Old Nov 18, 2004 | 08:42 PM
cappa's Avatar
are you trying to lock them with the door open? if thats the case it wont lock from the power switch with the door open.
Old Nov 18, 2004 | 08:43 PM
huntarrr's Avatar
If you try to lock the drivers door (as well as all the others) when the driver door is open, the driver door will not lock (this is normal). Like ^he^ said, hold the handle (on the door panel) open, and press lock at the same time and the drivers door (and the 3 others) should lock.
pwyley
Acura TSX
Apr 2, 2018 02:32 PM
nismogrendel
Jan 26, 2013 07:34 PM
William1991b
Jun 26, 2011 04:00 PM
rtcpenguin
Honda Civic (2001 - 2005)
10
Aug 3, 2006 07:39 PM
ALF
Jun 11, 2003 03:19 PM
