d16y8 intake manifold removal question - searched
Old Nov 18, 2004 | 08:14 PM
atc5's Avatar
Default d16y8 intake manifold removal question - searched
so I'm putting a manual intake manifold onto my d16y8 which was an auto, but is now a manual. I'm running the right ecu and everything.
I'm pulling out the auto intake manifold and the bracket on the back is stopping me from taking it entirely out. Should I just remove that large black bracket or is there something else I can do to manuever the IM out?
Thanks
Old Nov 18, 2004 | 08:16 PM
civictildeath's Avatar
Default Re: d16y8 intake manifold removal question - searched (atc5)
well if it is stopping you then i would say remove it and put it back after you get the other one in
Old Nov 18, 2004 | 08:17 PM
atc5's Avatar
it's a real nightmare to get at the bolts that hold the base of the bracket....i guess i'm looking for an easy way around this.
Old Nov 18, 2004 | 08:58 PM
Redline96LX's Avatar
* B A N N E D *
I swapped manifolds before. The bracket really isnt that hard to get off. Get a short socket, get it back there (you should be on the left side of the engine bay), feel around for the bolts and if you need, get the socket on the bolt before the wrench. Its a lil bit of a pain, but very do-able. Ive done it, trust me.
Old Nov 18, 2004 | 11:13 PM
brentmc79's Avatar
Default Re: d16y8 intake manifold removal question - searched (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">I swapped manifolds before. The bracket really isnt that hard to get off. Get a short socket, get it back there (you should be on the left side of the engine bay), feel around for the bolts and if you need, get the socket on the bolt before the wrench. Its a lil bit of a pain, but very do-able. Ive done it, trust me.</TD></TR></TABLE>
Exactly... It took me a few minutes, and it was kind of a bitch, but this is exactly what I did.
DrewMD
14
Nov 12, 2021 09:59 AM
tlarimer
Feb 16, 2013 08:18 PM
lilcasino
Nov 10, 2004 12:06 PM
Aeka GSR
Sep 14, 2003 09:19 PM
D15VTEC
Mar 29, 2003 05:03 PM
