mini me boost question
Old Nov 18, 2004 | 07:42 PM
luckecharm2004's Avatar
Default mini me boost question
i have a mini me right now..and i want to boost it..will a t 25 be ok to boost it? what recommendations are there for boosting the high compression mini me...also can i lower the cr of the mini me?
Old Nov 18, 2004 | 08:12 PM
mrspeaker's Avatar
Default Re: mini me boost question (luckecharm2004)
t25 has an internal wastegate set at 10-12psi from the factory..
If you get that turbo you might wanna think about getting a different spring for the wastegate to lower the boost....
You can stack headgaskets to lower the compression..I dont know how reliable it is but People have done it before..
Old Nov 18, 2004 | 09:19 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
t25 is an awful small turbo. i wouldnt use one on anything bigger than a dpfi 1.5. since youre a vtec 1.6 that will see what, 7500, 8k? i would go t3 .60 and up. the rod to stroke ratio of the d16's makes them lively on the bottom and taper off up top. a larger turbo will be less restrictive, create less reversion, and pull right to the redline. the car will feel lively from top to bottom. a t25 will be instant boost jerkiness that chokes the exhaust flow on top and kills torque.
Old Nov 20, 2004 | 05:32 AM
dr_latino999's Avatar
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">t25 is an awful small turbo. i wouldnt use one on anything bigger than a dpfi 1.5. since youre a vtec 1.6 that will see what, 7500, 8k? i would go t3 .60 and up. the rod to stroke ratio of the d16's makes them lively on the bottom and taper off up top. a larger turbo will be less restrictive, create less reversion, and pull right to the redline. the car will feel lively from top to bottom. a t25 will be instant boost jerkiness that chokes the exhaust flow on top and kills torque. </TD></TR></TABLE>
This just sounds wrong on....................5 different points.
1) T-25 is fine, you won't need anything bigger for now, especially with the higher compression ratio.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://homemadeturbo.com/tech_....html &raquo;</TD></TR><TR><TD CLASS="quote">The Compressor housing makes the T-25 turbocharger very easy to work with.
Overall, this turbo is a great turbocharger if you like incredibly fast spooling turbo's. But does not pull nearly as hard at 12psi that a 14b does</TD></TR></TABLE>
2)Where is the huge difference other than 100ccs between the 1.5s and the 1.6s? You make them sound as if they are world's apart.
3) You say the 1.6 will be seeing "7500-8000" when in fact the 1.5s are able to do this easier due to having the BETTER rod-stroke ratio between the two. How does the rod-stroke ratio change when the power is made?
4)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Some Turbos spool fast, some Turbos spool slow. The larger the A/R the more CFM it will flow, and the more lag it will have. Most of the .48 turbos spool very fast with D-series Motors. </TD></TR></TABLE> T3 .6?
5)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Michael Delaney &raquo;</TD></TR><TR><TD CLASS="quote">This need for backpressure no longer exists when you have a properly tuned (timed) engine and a good stepped header. In fact, increased backpressure may lead to backwards flow or "reversion", where the exhaust gas travels backwards into the combustion chamber and dilutes the fresh intake charge at cam overlap. At the very least, it slows exhaust flow velocity or energy and prevents the creation of a vacuum for scavenging.
</TD></TR></TABLE> A proper turbo setup will not have reversion (as far as I can say with my knowledge of exhaust flow) as the exhaust does not have a chance to flow backwards. It is continuously pulled toward the turbo and pushed out of the cylinder by the intake charge. You also act as if the T25 will "jerk" the car around as if it has full boost at 10RPM. Yes, I said 10. How will that choke the exhaust flow and lower torque? Do not apply Naturally Aspirated Logic to a case of Forced Induction
Modified by dr_latino999 at 10:30 AM 11/20/2004
Old Nov 20, 2004 | 08:14 AM
Sikocivic's Avatar
I agree 100% with dr_latino999 on this. That T-25 will be fine. Spend your money on GOOD fuel management.
SOHC_MShue
Jun 15, 2004 09:52 PM
onePOINTsix
Aug 19, 2003 10:59 AM
Mr. Softee
Jul 8, 2002 06:54 AM
M.A.R.C.
Jun 9, 2002 06:31 PM
Integra187
Sep 21, 2001 07:13 PM
