d16z trubo
how much psi would yall run on a stock d16 i mean not even a short ram. and would it be pretty fast? its a greddy kit turbo ,intercooler, wastegate,injectors, blow off valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmycell »</TD></TR><TR><TD CLASS="quote">how much psi would yall run on a stock d16 i mean not even a short ram. and would it be pretty fast? its a greddy kit turbo ,intercooler, wastegate,injectors, blow off valve </TD></TR></TABLE>
wow
wow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel_san »</TD></TR><TR><TD CLASS="quote">
wow
wow
wow
stock d16 should hold whatever you want, but without having start replacing fuel items most guys stick to lucky number 7, more than that on most setups your gonna have to replace injectors and Fuel pump and get some real tunning done, crappy VAFC's wont cut it here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmycell »</TD></TR><TR><TD CLASS="quote">thanks man your kool they suck ***</TD></TR></TABLE>
They probably didn't want to try and translate that grammatical clusterfuck you consider a question.
Could you explain what that sentence means? have no idea what your talking about in that sentence. I recommend 7psi or less.
THAT IS TO BAD CAUSE I OWN A ACURA ****** AND THAT DEL SLOW IS NOT EVEN MY CAR I WAS JUST TRYING TO SHOW MY FRIEND THAT U CANT RUN 13 PUNDS ON STOCK RODS STOCK PISTONS STOCK ROD BOLTS AND BY THE WAY I OWN A INTEGRA
tell your friend to try and run 13 pounds of boost on a stock bottom end. then he'll find out if it can handle it. lol
wow
wow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmycell »</TD></TR><TR><TD CLASS="quote">THAT IS TOO BAD CAUSE I OWN AN ACURA ****** AND THAT DEL SLOW IS NOT EVEN MY CAR I WAS JUST TRYING TO SHOW MY FRIEND THAT YOU CANT RUN 13 POUNDS ON STOCK RODS, STOCK PISTONS, STOCK ROD BOLTS AND BY THE WAY I OWN AN INTEGRA </TD></TR></TABLE>
Go back to grade school.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmycell »</TD></TR><TR><TD CLASS="quote">THAT IS TO BAD CAUSE I OWN A ACURA ****** AND THAT DEL SLOW IS NOT EVEN MY CAR I WAS JUST TRYING TO SHOW MY FRIEND THAT U CANT RUN 13 PUNDS ON STOCK RODS STOCK PISTONS STOCK ROD BOLTS AND BY THE WAY I OWN A INTEGRA </TD></TR></TABLE>too*, an* acura , pounds*; and u forgot a couple commas. and why did u say you own an integra twice? that was the first thing you said and then u said it at the end. but 9 psi max
Bet I can prove that one wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic »</TD></TR><TR><TD CLASS="quote">
Bet I can prove that one wrong</TD></TR></TABLE>
PROVE WHAT WRONG
PROVE WHAT WRONG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshmycell »</TD></TR><TR><TD CLASS="quote">HOW MUCH CAN THAT PIECE OF **** SINGLE CAM TAKE BEFORE BLOWING </TD></TR></TABLE>
If its a POS why dont you just give it to someone that will use it correctly, like me.... but it should be able to hold 200whp DAILY some healthy D16z6 have been said to hold 250whp on stock internals but i doubt they drove it like that daily...
edit: I forgot to tell u that it depends on the shape of ur motor, if its in good healthy running order, it can take the above if not, i suggest a mild rebuild...
And when u ask how much a motor can take, refer to it in hp number not in Psi, because different turbos and setups make different power at the same psi...
And for a newbie, dont be so cocky....
another factor in how much boost it can handle is where it's going to be driven, temperature and everything. stock greddy kit is 5.5psi i believe, without intercooler. with a good intercooler, i'd say 9-10 psi, but the rods on a z6 are so small i'd be worried even at that level of boost. if he wants it to be fast, spend some money, sleeve the block, get new rods/pistons, upgrade the fuel system, get a turbo kit with intercooler, and a good program running it all
Coke in a Can
Oct 14, 2007 12:33 PM
Coke in a Can
Oct 12, 2007 09:31 PM
Mikes2000civicsi
14
Nov 21, 2006 01:57 PM
