90-93 integra rails same as 88-91 crx/civic??
just as the topic states.. i was curious if the seat brackets are the same or not? the brackets on my stock seats are brocken so i wasn't sure if i could go getting some integra ones and it will be the same.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote">i beleive 3 of 4 bolts line up.
dont quote me on it though. </TD></TR></TABLE>
correct to a extend the third one is a pain but will bolt up
there rails are a bit larger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 »</TD></TR><TR><TD CLASS="quote">correct to a extend the third one is a pain but will bolt up
there rails are a bit larger</TD></TR></TABLE>
thanks for clarifying!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF »</TD></TR><TR><TD CLASS="quote">ohh.. alrite.. thanks for the info guys.. so i have to have ef brackets.. makes the search a lil more difficult
To properly install DA seats into a CRX, you need to swap the seat pans.
i have 90-91 LS seats in my 91 hatch. Its true that 3 of the 4 bolt holes line up, but if you position the seat in this way, you will notice that it sits at a very awkward angle.
How i installed mine was use the integra brackets... cut the front mounts off the integra brackets and the civic brackets, and then bolt or weld the civic front brackets onto the teg rails. this will make the front bolt holes line right up. then for the back, i had to make a space for one side (the angled bolt hole one) becuase it sat back about 3/4" too far, and the other side, (flat bracket side) i had to notch the bolt hole a little and make another spacer so the seat would sit level.
From: not riding any bandwagons in, massachusetts, usa
ef's have several different styles. 4 door, 88-89 and 90-91. i dont think ls pan can be switched around with 88-89.. the seats didnt get wider till 90. 4 door might be 88-91 or might be divided. unsure there as well
wow thanks for all the info guys.. see i'm getting this 90 civic hatcha nd it has gen 2 integ seats but they aren't bolted in really.. so i'm trying to analyze the situation basically.. i'm thinking about just getting some crx or civic seats and save the head ache...
4drferio
Jul 13, 2007 09:24 AM
