Stock K20A tuned by Chruch's
Old Nov 18, 2004 | 12:30 PM
SuperTwinz's Avatar
Default Stock K20A tuned by Chruch's
Stock K20A in EG with R Crew header, full exhuast with, pump gas tuned by Church's Automotive: Dynapak reads higher then Dynojet.
Green is tuned. He can take it to 9K and make more power but didn't want to risk hurting the motor.
Old Nov 18, 2004 | 12:32 PM
JDMlyfestyle's Avatar
Afr is pretty shaky
Old Nov 18, 2004 | 12:38 PM
Ekizzle's Avatar
Default Re: (JDMlyfestyle)
Old Nov 18, 2004 | 01:17 PM
chris_m's Avatar
* B A N N E D *
Default Re: (Ekizzle)
a/f is all over the place
Old Nov 18, 2004 | 01:21 PM
SuperTwinz's Avatar
Default Re: (alld16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alld16a &raquo;</TD></TR><TR><TD CLASS="quote">a/f is all over the place</TD></TR></TABLE>I agree with that.
Old Nov 18, 2004 | 01:27 PM
B18OnTop's Avatar
Default Re: (SuperTwinz)
Nice #s. Any pics?
-Aaron
Old Nov 18, 2004 | 01:28 PM
SuperTwinz's Avatar
Default Re: (B18OnTop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18OnTop &raquo;</TD></TR><TR><TD CLASS="quote">Nice #s. Any pics?
-Aaron</TD></TR></TABLE> I need to take pics.
Old Nov 18, 2004 | 01:50 PM
Professor15's Avatar
And that is pretty much why i decided to go K and not build a B-series...
Modified by drchulo at 6:31 PM 11/18/2004
Old Nov 18, 2004 | 02:08 PM
miller's Avatar
Default Re: (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo &raquo;</TD></TR><TR><TD CLASS="quote">And that is pretty much why i decided to gay K and not build a B-series...</TD></TR></TABLE>
yes we are all aware of your " gay" tendency's.
oh and yes that afr is all over the place.
Old Nov 18, 2004 | 02:09 PM
miller's Avatar
Default Re: (miller)
but the graph looks good
Old Nov 18, 2004 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">
oh and yes that afr is all over the place. </TD></TR></TABLE> Dammit that suppose to say "GO" and shut up and go build me my K-series already...
Old Nov 18, 2004 | 02:18 PM
ISawUL00k's Avatar
I should be called Gay series the cars they are in sure are. good power for
$10 grand starting block.
all that hp and trq are great but can u go anywhere with it.
mini van motorsports..
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
shawn
Old Nov 18, 2004 | 02:44 PM
Hondog's Avatar
Default Re: (HOOKUPS)
What gear is that done in???? I'm guessing 3rd???
The Ratio is miles higher than where mine is.... My ratio is at 5.760 running in 4th on a JDM 6spd... If I used your ratio and 3rd I'd be pumping over 270whp...
Old Nov 18, 2004 | 03:08 PM
12secAllMotor's Avatar
Default Re: (Hondog)
Go k-serie, not B.
Old Nov 18, 2004 | 03:16 PM
SuperTwinz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog &raquo;</TD></TR><TR><TD CLASS="quote">What gear is that done in???? I'm guessing 3rd???
The Ratio is miles higher than where mine is.... My ratio is at 5.760 running in 4th on a JDM 6spd... If I used your ratio and 3rd I'd be pumping over 270whp...</TD></TR></TABLE> 5.0 final drive is what is in the tranny.
Old Nov 18, 2004 | 03:17 PM
SuperTwinz's Avatar
Default Re: Stock K20A tuned by Chruch's (SuperTwinz)
BTW this is not my car. It belongs to RyanR which he built for road racing.
Old Nov 18, 2004 | 03:34 PM
justBLZE's Avatar
Chopper 2 Hopper
How much would that be on a dynojet?
Anywhere around 220 are solid numbers, good job.
Old Nov 18, 2004 | 04:00 PM
SuperTwinz's Avatar
Heres a pic of the header:
Old Nov 18, 2004 | 04:04 PM
SuperTwinz's Avatar
https://honda-tech.com/zerothread?id=1002488
Old Nov 18, 2004 | 04:17 PM
NSTY Z33's Avatar
crazy
Old Nov 18, 2004 | 04:50 PM
Ekasey's Avatar
Default Re: Stock K20A tuned by Chruch's (CRXDelSol!)
Extremly long header looks good but loooooooong
Old Nov 18, 2004 | 05:51 PM
JDogg's Avatar
Default Re: Stock K20A tuned by Chruch's (eLusive ek4)
using a different gear on a dynapack dosnt matter unless you have no idea how to set it up. also.. if its setup right it will read right in line with a properly setup dynojet.... at least mine does.
good numbers though
Old Nov 18, 2004 | 06:42 PM
prestonpark's Avatar
Default Re: Stock K20A tuned by Chruch's (JDogg)
so all u did is change the dtr headers for r crew headers ?
Old Nov 18, 2004 | 06:53 PM
Allmotor2o9's Avatar
Default Re: Stock K20A tuned by Chruch's (civic2003)
nice numbers for flywheel hp... whats the whp??
