h22/ek harness
Only EK harnesses work in EK chassis. You can modify your harness to work, no matter what trim level or motor you have. Of course if you have a stock VTEC engine you have an advantage already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.soundbomber.com »</TD></TR><TR><TD CLASS="quote">if you have a 98, get a 96-98 ex harness, if you have a 99+ get a civic si harness</TD></TR></TABLE>
There you go dude! You will still have to probably lengthen a few branches or whatever to make sure it all reaches comfortably, and I think the H22A has IAB on it like the GSR intake manifold, so you'd need to add a wire the the ecu plug and a ground wire on the engine side but that's about it. Depending on what ecu you run with you may be able to ignore some sensors too.
hey man spend some time reading this it should answer all your questions.
https://honda-tech.com/zerothread?id=650329
