JDM ITR cluster dilema solved (kinda)
Old Dec 27, 2001 | 04:57 PM
kenji's Avatar
25 Year Member
Default JDM ITR cluster dilema solved (kinda)
OK, here's the deal...
1998 USDM ITR (car)
1996-1997 JDM ITR instrument cluster
Initially, the seat belt light was on all the time and the gas gauge did not work.
Solution: Remove the "circuit plastic sheet" and swap them.
Result: The gas gauge works and the seatbelt light is not on all the time and I am happy.
For those of you who said that the "circuit plastic sheet" is the same between the USDM & JDM ITR you are incorrect. There are slight differences in the area of the seatbelt light. Nothing big, but enough to not make it work right.
Another thing I noticed is that the gauge clusters themselves are slightly different (e.g. the seat belt light is in a different spot as well as the open door indicator). Also, there is no SRS and ABS lights on the JDM ITR cluster. In addition to this, the JDM ITR cluster has a catalytic converter heater light (it looks like a steaming hamburger).
One other thing, due to the different position of the seatbelt and open door indicator lights the seatbelt light lights up when the doors are open.
Hope this helps you guys in the future.
-kenji
Old Dec 27, 2001 | 05:00 PM
yoshi234's Avatar
I shoot brides
Default Re: JDM ITR cluster dilema solved (kenji)
-kenji
Thanks kenji
Old Dec 27, 2001 | 05:57 PM
jeff652's Avatar
Kenji,
You are still the man!!
Jeff
Old Dec 27, 2001 | 06:00 PM
Type R's Avatar
OT: Bad *** avatar you like cky?
Old Dec 27, 2001 | 06:26 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
kenji.. what the funk am I supposed to do with you. lol I could have saved you a solid.. 15 minutes there! hehe. In the case of my GS-R cluster.. it was easier to swap the gauges rather than the motherboard. This is the method I suggest to people, and of course to check the light sheets. Some older clusters (older gs-r's for example) have the icons located in different spots, so swapping the gauges and those plastic light sheets is a solid 10 minute job probably.
-Dave, who has been using a JDM ITR cluster for... awhile.
Old Dec 27, 2001 | 06:32 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: JDM ITR cluster dilema solved (Dave-ROR)
You are my hero
Old Dec 27, 2001 | 06:49 PM
TRuST's Avatar
So you just swapped out the guages GSR gauges with the ITR guages ?!
Did you have to re-wire anything ? Or are the guages Plug and Play ?
Old Dec 27, 2001 | 06:57 PM
b00st-0wnz's Avatar
Default Re: JDM ITR cluster dilema solved (TRuST)
The gauges are all mounted the same way, in the same located. The motherboards are different. Kenji switch the motherboard, I found it to be easier to switch the gauges. You just put the ITR gauges into the GS-R cluster backplate/housing, switch the CF cover if you want the fake CF vs the black, screw it back together and your done.
Old Dec 27, 2001 | 10:21 PM
Mike M's Avatar
Founding Member
The Circuit boards for 94-96 is marked 723A, the ones on a 98 ITR are marked 723C. I have been told that you can get them from Acura.
Old Dec 28, 2001 | 03:52 AM
kenji's Avatar
25 Year Member
Default Re: JDM ITR cluster dilema solved (TypeRmsm)
Dave,
I guess I could have done what you mentioned (transplanting the JDM ITR gauges in the USDM ITR cluster). But, if I did that I would not have the hamburger heater light . I am probably going switch the gauges out in the near future.
-kenji
CKY is good
Old Dec 28, 2001 | 05:52 AM
b00st-0wnz's Avatar
Dave,
-kenji
CKY is good
Yeah you would The traces are on the USDM motherboard, just switch over the hamburger heater light sheet
Old Dec 28, 2001 | 05:53 AM
b00st-0wnz's Avatar
Oh yeah, I removed the HH light sheet, removed the bulb for maint req'd, the bulb for cruise.. and the CEL.
Old Dec 28, 2001 | 05:56 AM
TRuST's Avatar
Thanks, Dave. I'll give it a try when I get my guages.
Old Dec 28, 2001 | 10:18 AM
Mike K's Avatar
You should wire that 'hamburger heater light' to your VTEC, so when VTEC pops, the things starts "cookin"! lol.
Hey Kenji... go punch yourself in the nuts again.
thegatekeeper14
Oct 29, 2009 07:50 PM
96CivicBoostCoupe
Dec 18, 2005 04:39 PM
kenji
Aug 11, 2005 11:09 AM
Outkast_CL9
Aug 11, 2004 11:08 PM
Seedc2
Apr 25, 2004 09:54 PM
