helms idle adjustment procedure
Old Nov 18, 2004 | 11:09 AM
jackstands's Avatar
Default helms idle adjustment procedure
I followed helms' idle adjustment procedure, but when I unplug the IAC, car cuts off. What am I suppose to do now? Here's my problem, car will not idle when it's cold, it will idle sitting still until I drive it, then at the first light, it will stall out.
Old Nov 18, 2004 | 05:49 PM
jackstands's Avatar
Default Re: helms idle adjustment procedure (jackstands)
bump
Old Nov 19, 2004 | 05:30 AM
Daemione's Avatar
I think it says this in the Helms, but make sure there's no load on the engine when you unplug the IAC (no lights, fans, etc.). Also, have the engine already completely warmed up before you try it.
Where is your idle when it's running? If it's at the right place and still stalling out every time you come to a stop, bumping the idle will only be a band-aid. You want to find the real problem - most likely something to do with the IAC. Have you tried cleaning the little screen inside it? Sometimes that can get built up with crud and hurt it's performance. Just pull off the IAC, you'll see the screen I'm talking about.
lrhtech
24
Mar 8, 2016 04:00 PM
Elvis1977
Apr 1, 2009 04:13 PM
minner
Oct 8, 2006 01:30 PM
carblegal
Dec 25, 2004 09:51 PM
Jet Black
11
Nov 24, 2004 08:22 PM
