Honda Access door visor (how too)
Old Nov 18, 2004 | 08:17 AM
BUKKAKE-ADAM's Avatar
Default Honda Access door visor (how too)
somebody please help me, how do you install the jdm door visors on the eg6. if you could help that would be great.
Old Nov 18, 2004 | 08:22 AM
EkEli's Avatar
rebmem roines
Default Re: Honda Access door visor (eg_adam)
https://honda-tech.com/zerothread?id=632263
Search could help. I guess you just need help from other.
Its pretty much the same for the eg.
Old Nov 18, 2004 | 02:57 PM
thanks alot bro but the ek is different from the eg...
Old Nov 18, 2004 | 03:00 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: (eg_adam)
From what I hear it is, I just don't see how different it could be. Bump for you anyway, if you want some more EK how-tos I'll post if you think they would help.
Old Nov 18, 2004 | 03:15 PM
b18bEG's Avatar
sorry to hijack, where did you get your visors at? the EG should be somewhat like the EK ones..
Old Nov 18, 2004 | 03:20 PM
S.W.A.P.'s Avatar
adam,
what up you need help, alittle how to..
1) window down
2) start from the heal or the rear section, so that you line it up perfect with the plastic door pillar
3) start to pull the rubber on the outside of the door
4) snap the metal clip in to the grove (self fitting)
5) and replace the rubber
6) continue till done and then switch sides.
I found that its easier to put the rubber back in reaching from the inside of the window out.
good luck and keep it real,
adam
Old Nov 19, 2004 | 08:13 AM
thanks for the get backs i'll be installing today.
EKSedAndy
Mar 18, 2009 03:06 PM
T S R Performance
Sep 15, 2006 11:54 AM
jessemarCc
Aug 12, 2004 10:49 PM
JDM_EK3
Dec 31, 2003 07:39 AM
Beatkidd
Sep 10, 2003 01:33 AM
