Apexi N1 routing
Old Nov 18, 2004 | 07:32 AM
wheatfroggy17's Avatar
Default Apexi N1 routing
This is my first time posting on HT, but can anybody post a pic of the exhaust routing of an Apexi N1 on a 92-95 civic coupe. Or does anybody know if the Suspension Techniques sway/tie bar combo will clear it? Unless somebody already has tried this setup, I have found the only way for people to say anything about it is to compare. So could anybody post a pic of the routing of the N1 out the back?
Old Nov 18, 2004 | 08:02 AM
revvin9k's Avatar
Default Re: Apexi N1 routing (wheatfroggy17)
I don't see why the N1 would be any different from any other exhaust. I have the Skunk2 full catback and have no problems ith my ST sway bars. Good luck.
JDMH22HATCH's Avatar
Here's mine with the S/T sway bars.
Old Nov 18, 2004 | 08:46 AM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: Apexi N1 routing (JDMH22HATCH)
i believe that pic above is the old design.. the "newer" design doesn't route under the LCA... someone correct me if im wrong
Old Nov 18, 2004 | 08:58 AM
mwieczorek43's Avatar
Default Re: Apexi N1 routing (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">i believe that pic above is the old design.. the "newer" design doesn't route under the LCA... someone correct me if im wrong</TD></TR></TABLE>
Yes you are definatly correct about this. I have the old design... my buddy has the newer design. Totally different.
If you are running the piping correctly (not upside-down... dont laugh, alot of people do it with this exsaust) you should not have any clearance issues with your bar(s).
Old Nov 21, 2004 | 06:18 PM
A.E Motoring's Avatar
yeah i would like to see some pics too
Old Nov 21, 2004 | 06:56 PM
itsJDMyo's Avatar
Default Re: (JDM BoI)
bump, becuase i'm planning to do a custom setup with my apexi N1 also
Old Nov 22, 2004 | 04:15 PM
itsJDMyo's Avatar
Default Re: (itsJDMyo)
Old Feb 24, 2005 | 07:37 PM
dawrenn's Avatar
Default Re: Apexi N1 routing (mwieczorek43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 &raquo;</TD></TR><TR><TD CLASS="quote">
If you are running the piping correctly (not upside-down... dont laugh, alot of people do it with this exsaust) you should not have any clearance issues with your bar(s).</TD></TR></TABLE>
Are they both still angled?
Old Feb 24, 2005 | 07:39 PM
McNizzle's Avatar
Default Re: Apexi N1 routing (dawrenn)
The newer design has just a very SLIGHT angle. Not nearly as noticeable as the older version. It's still nice to me IMO.
Old Feb 24, 2005 | 07:46 PM
nfinitecc's Avatar
Default Re: Apexi N1 routing (Chris M)
Are the N1 batbacks all angled? i really want the old design with a super angled look for my del sol. If you know TELL ME so i can go buy it.
Old Feb 24, 2005 | 07:57 PM
komat's Avatar
Default Re: Apexi N1 routing (nfinitecc)
what are some other exhaust that are in an angle
Old Feb 24, 2005 | 08:25 PM
jeffk182's Avatar
HKS Hi Power
JDM Lyfestyle
Feb 27, 2009 08:37 AM
ubreak_ubuy
Apr 23, 2005 05:51 PM
AzNjL427
Jan 29, 2004 08:57 PM
jdmSiT
Jun 14, 2003 01:55 AM
sshaikh01
30
May 20, 2003 09:15 AM
