Need Help with Tranny fluid
Hi, anyone know how to change tranny fluid in my 5th Gen prelude??? I know u can do it in automatics but i have a manual and im grinding in 3rd.....
Plz help
thanks
Plz help
thanks
I changed mine again last night. It is pretty easy. Almost as easy as changing the engine oil.
What I did was I bought a transparent, flexible tube and routed it from the engine bay down to the filler hole in the tranny.
Open the filler hole plug and the drain plug. They are right next to each other. Put the bottom drain plug back in. Then put the tube into the filler hole and pour the oil in until it starts pouring out of the filler hole. You are done at that point.
It shoudl take a little less than 2 quarts.
The flexible plastic hose makes it VERY easy. It only cost me $2 too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan »</TD></TR><TR><TD CLASS="quote">You can also buy a funnel with the hose attached at just about any auto parts store. Thats what i use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude »</TD></TR><TR><TD CLASS="quote">does the diff fluid come out with the tranny fluid or is it in a different place?</TD></TR></TABLE>
if i'm not mistaken, they're the same thing in the FWDs. one more good thing about having a Honda FWD.
firstly, if you have a us trans, w no lsd, it will take a bit over 2 qts of fluid so be sure to buy 3, that would suck if you came up short at home/no other car.....
also, the diff uses the trans fluid also, and most of the fluid in the diff comes out from the drain plug, but you can take the very lowest bolt on the farthest part out on the trans and maybe get a little more out, i cant remember if its lower than the drain plug, i drained one with it out of the car hanging from a lift....
One piece of advice. Since it looks like its the first time you're doing this, unbolt the filler bolt before the drain bolt. You wouldn't want to leave yourself stranded because you had trouble undoing the filler bolt(which could be a pain sometimes).
that is all...
that is all...
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
pelotudo
Jul 21, 2002 02:33 AM
