what the heck! Handling newbish question
Old Nov 18, 2004 | 06:50 AM
wootcivic's Avatar
Default what the heck! Handling newbish question
I would like anyone with feedback to post their thoughs about what I should be looking for.......
Problem - Car will pull very sharply to both left or right depending on road conditions (NW Chicago IL roads are the sux0r). Major understeer when taking <110 degree turns... Seems to be a clicking sound coming from passenger rear shock tower.
What I've looked into all ready - I have checked for bent and or loose connections.. Nothing found. I have took the car to honda to see if I might need a alighnment, said no it's my after market rims/tires but nothing is bent...
Car Setup - 99' Civic DX Hatch. TOKICO Illumina 5 way adjustable with matching springs set on the stiffist setting (5). Dropped about 1 inch, arowspeed ajustable camber kit (not wearing tires! So no camber issue after 10k+ miles) on American Racing 17x7 42mm offset wrapped with Kumho ECSTA 711 205/40-17 rubbers..
Is anyone able to see a problem with the setup it's self, or have any ideas what I should be looking for? I have exhusted my efforts at this point. The car is "driveable", but is in my own opinion, unworthy of street use.
Mark
Old Nov 18, 2004 | 07:25 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: what the heck! Handling newbish question (wootcivic)
hmmm.....lower profile tires are very prone to following grooves in the road, so it could be that. I know when I ran 17" rims on my Civic it could get a litle scary at highway speeds on worn roads with it becoming "darty". When I switched back to lightweight 15"wheels my car now rides like a Cadillac but still handles every bit as good as before and it's not really affected by road ruts (my tires are 205/50/15 now).
If your tires are worn on the insides at all from improper camber, that will only contribute even more to the car wanting to follow the ruts in the road. I think you're running your shocks a little to stiff as well, try setting your fronts on 4 and your rears on 3 and see how the car feels. Also make sure you're not running to much air pressure in your tires, try going with the factory specs listed in your door jam + 5 psi (because of the 17" size). Higher psi will better protect your tires from blowing out a sidewall or bending a rim when hitting a pothole.
The last thing I would suggest is a swaybar for the rear of your car, this should eliminate your oversteer problems. A stock rear bar from an 99-00 Si would help but a larger bar from Suspension Techniques or an ITR would be even better.
Old Nov 18, 2004 | 07:40 AM
Feriofan's Avatar
00Red_SiR ^^ just provided the same answer that I had for your issue, I had the same exact problem.
Old Nov 18, 2004 | 08:45 AM
wootcivic's Avatar
Default Re: what the heck! Handling newbish question (Feriofan)
Awsome, thanks for the feedback! I have messed with the shock settings, stiff in the front (setting 5) and 3 in the rear, but that seems to make the problem only worse. Plus, if I make the rear as loose as a goose, it wants to rub the fenders under low speeds. I think I'm going to raise the car a few more turns and re install the rear anti-sway and see what happens.
If all else fails, I'll loose the wheels and throw on the stock steelies until I can find a more suitable configuration..
jmandawg
Suspension & Brakes
23
Nov 5, 2012 03:53 PM
sidoe
Suspension & Brakes
10
Mar 1, 2008 06:13 AM
MikeLuder
Nov 30, 2006 03:22 PM
99DXcoupe
Sep 27, 2002 09:35 PM
