2003 civic cluth
hi guys, i was trying to teach my brother how to learn stick shift and i guess i will need to change my clutch. can someone advise me how to change clutch ? I am not a mechanic but i can do it if i have the instructions. also, how to flush out the clutch system ? and what type of fluid should i use for this. Any advise will be helpful. Thank you
search
you are the newest member of my club
**THE PEOPLE WHO DO NOT KNOW HOW TO USE THIS SITE CLUB**
i will keep u updated on any new additions to this up and coming crew
If you're going to flame, at least use some grammar. And u is not a word.
To the OP, why do you think the clutch is gone? If it's a 2003, I find it hard to beleive that a few lessons on driving would burn it out.
I've tought quite a few people on my car, and have tracked it regularly for 3 years. It has 100K on the clock now, and is just starting to go. Tell us your symptoms so we can help.
it doesnt feel smooth as it used to be. Other than that i dont have any problem with it. what will cure this ? also going to to do MTF change. will hond MTF be ok or i should go with GM synchromesh. what is your suggestion,
Honda MTF all the way.
If you can still change gears your "cluth" is okay
Do you have more than 30,000 mile on the trans? If not you don't need to change the fluid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by return_2020 »</TD></TR><TR><TD CLASS="quote">it doesnt feel smooth as it used to be. Other than that i dont have any problem with it.</TD></TR></TABLE>
Then it's probably fine. It may just be getting worn in; or possibly you're just paying more attention to the clutch (to see if he damaged it) and it's been the same all along, now you're just noticing a different feel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by return_2020 »</TD></TR><TR><TD CLASS="quote">going to to do MTF change. will hond MTF be ok or i should go with GM synchromesh. what is your suggestion,</TD></TR></TABLE>
I used MTF a few times, and it did the job as well as the synchromesh does; but I don't have any grinds, so to me they performed similar.
I use this now:
http://www.stealth316.com/2-pe...h.htm
readily available, same as GM, and much cheaper than Honda or GM.
I use this now:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">
I got Honda MTF at an Acura Dealership for under $4 a quart. IN the link you posted it says that Penzoil stuff costs around $5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">
I got Honda MTF at an Acura Dealership for under $4 a quart. IN the link you posted it says that Penzoil stuff costs around $5.</TD></TR></TABLE>
I guess you'll just have to check around where you live. I pay $5 or so for the Honda at my dealer, and the GM / Penzoil stuff is around 3.50 - 4.50 depending on which part store I go to. Either way, even if it was $2 more (the GM Friction Modified is actually about $10 more), I'd still go with the Synchromesh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by return_2020 »</TD></TR><TR><TD CLASS="quote">i just called and HOnda MTF is $5.50 and GM synchromesh is $11.00. does it make sense?</TD></TR></TABLE>
Yeah, the synchromesh is more at the GM dealer. Just go to autozone and get the Penzoil stuff. Penzoil makes the GM fluid for them. I worked at the company that helped develop it, so I know first hand.
