Easy to reach radio wires?
I'm going to try to tap into the power and ground wires in my stock radio. ('97 teg, coupe, gsr). Does anyone know if I can reach the wires without taking the radio, console out? Thanks. Oh yeah, I'm hookin up my shift lite.
From: Formerly of SF moved to DFW and now back in SF, CA, USA
When I tapped into the radio wiring harness I had to pull the console out of the way as well as pull the radio out. It's a tight fit back there so it'll be easier to pull the radio out to access the wiring. Some parts are sharp back there also, so be careful. Good luck!
Forget the radio, goto the fuse box. Nice little spade terminals there to get easy power. There are 5 male spades across the top.
Of the right 3, one is constant 12v, one is switched with the igntion, and one is switched with parking lights.
Very simple eh?
Very simple eh?
Ashlyn26
18
Jun 29, 2016 06:44 PM
AccordDrivah
Mar 25, 2012 07:24 PM
