ENKEI RS7 Performance Rims.
Old Nov 17, 2004 | 08:13 PM
JDM_Powered's Avatar
Default ENKEI RS7 Performance Rims.
Does anyone know if these rims will fit in the wheel well of a '91 CRX? How much do these rims weigh anyways?
Old Nov 17, 2004 | 08:40 PM
91civicEX's Avatar
Default Re: ENKEI RS7 Performance Rims. (JDM_Powered)
depends on the size and offset and tire size not the type of rim. put that info up and someone can prolly tell u if itll fit.
Old Nov 17, 2004 | 09:10 PM
Mmmkay...This is on a 17" Rim
Offset: 42 (The Car will be lowered about 1.5 in.)
Bore Diameter?: 72.6
Tire: Nitto 555RII
Tire Size: P275/40 ZR17 98W
Tread Depth: 6.3 (1/32")
Tire Width: 10.79 in.
Overall Diameter (Inflated): 25.67 In.
Old Nov 17, 2004 | 09:47 PM
I called Discount Tires and they said they thought it would fit but im still unsure. They didnt sound all that sure about it...Help?
Old Nov 17, 2004 | 10:17 PM
Mr_CRX's Avatar
275's? dang. thats a fat tire. How wide is the wheel?
Old Nov 17, 2004 | 10:34 PM
eda6's Avatar
Default Re: ENKEI RS7 Performance Rims. (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Powered &raquo;</TD></TR><TR><TD CLASS="quote">Mmmkay...This is on a 17" Rim
Tire: Nitto 555RII
Are you serious 275/40/17? Got an nsx motor in the back?? That won't fit
Old Nov 17, 2004 | 10:53 PM
sherfield2002's Avatar
better make that tire 205/40/17 but i wouldnt put a 17" wheel on anyway. they are too big on a ef to me
Old Nov 17, 2004 | 11:20 PM
DJ_SaNdOz's Avatar
Default Re: (sherfield2002)
You will probably rub. I had RS6's in 17" on my 91 Si for awhile, and I was lowered on Neuspeed sport springs, and rubbed on big bumps, on corners, and with people in the back . 17's just look way to big on all civic's except the Ep3 IMO.
Old Nov 18, 2004 | 08:37 PM
Bump, Well doesnt matter either way now since im getting Enkei OR52's 16" with Falken Azenis.....Damn, this is gonna be a fun project.
Off topic, but if you put a B18c Type R in a '91 CRX, can you fit a Jackson Supercharger in with it? Please say yes....
Modified by JDM_Powered at 1:13 AM 11/19/2004
Old Nov 19, 2004 | 11:09 AM
91civicEX's Avatar
if you have enough money why not.
Old Nov 19, 2004 | 12:18 PM
90civichbsi's Avatar
Default Re: ENKEI RS7 Performance Rims. (91civicLX)
i can tell you that the wheels and tires will definitly not fit... if its a 275 tire.. its probably on at least a 8.5-9" wide wheel. and neither a 9" wheel or a 275 tire would fit. and if it is infact somewhere around a 9" wide wheel the wheel wouldnt even bolt up b/c the +42 offset would set it too far in and it would rub the rear trailing arm and the knuckle up front. and still rub the fenders.
the optimal size for no rubbing on an ef is:
15x7 wheel +42-45 offset, 205/50/15 tire
16x7 wheel +42-45 offset, 205/45/16 tire
or if you really want a 17" wheel
go 17x7 wheel +42-45 offset, and 205/40/17 tire (although it will probably rub in turns)
as for the supercharger question... yes it will fit w/ some modifications to the supercharger
check out this link: https://honda-tech.com/zerothread?id=510810
Although i think Jackson racing is comming out with a supercharger made for our swapped cars if its not already out but i hear its a lil pricey.
just a lil advice for your next thread, post a lil more info for your question and search a little b4 you start making new threads, welcome to H-T
Old Nov 19, 2004 | 11:01 PM
Thanks, but i didnt see the modifications you need for the supercharger. I saw the pic, but it didnt mention anything about additional parts (Atleast not that i saw)
Old Nov 21, 2004 | 06:44 AM
sorry you have to click a couple links... http://home.mn.rr.com/keebler6....html
j_mee_5
Jan 30, 2010 02:01 PM
tyronne1126
Honda Civic (2006 - 2015)
23
Mar 30, 2009 12:58 AM
snapper1978
Oct 26, 2006 10:09 AM
preludepower
10
Jan 1, 2006 01:18 AM
azian21485
Jun 3, 2004 11:33 AM
